Jd430 Weird Speed Changes...fixed :-)
34 replies to this topic
#1 olcowhand ONLINE
  • 41,072 Thanks
  • 31,393 posts
Posted February 18, 2013 - 12:01 PM
I got a wild hair to check out why my "new to me" John Deere 430 will change speeds at will while driving, usually only downhill.  It would be going along fine, then suddenly slow, then speed up again.  So I took off the rear fender pan & fuel tank, along with removing the mowing deck.  It didn't take long to see exactly why it is doing it.  Where the axle tubes bolt to the frame, the frame is broken & all is loose.  Also, the cross member at the front of the hydro is loose at the frame, and very loose where the single bolt goes into the front of the differential housing.  It flexes all over the place, so when hitting uneven spots in the ground, the speed changes are even worse.  But even on smooth ground it does it also, due to all the slop.  Here are some pics, and I'll add video later of how loose it is.
  • Texas Deere and Horse, KennyP, JDBrian and 5 others have said thanks
#2 olcowhand ONLINE
  • 41,072 Thanks
  • 31,393 posts
Posted February 18, 2013 - 12:10 PM
Here's proof in the pudding....well, in video!
  • Texas Deere and Horse, boyscout862, WNYTractorTinkerer and 1 other said thanks
#3 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted February 18, 2013 - 12:14 PM
Knowing what to fix is th first step. I can't wait to see how you do it!
#4 olcowhand ONLINE
  • 41,072 Thanks
  • 31,393 posts
Posted February 18, 2013 - 12:18 PM
I plan to weld up the cracks, then add a large piece of 1/4" angle iron to both sides to reinforce things.  Then I'll weld up the cross member bolt holes and re-drill to proper size.  Also, this cross member only bolts to one mount boss on the front of the differential housing, but I will alter it so it can bolt to both sides as I did on my diesel JB when I added this same hydro system to it.
  • Texas Deere and Horse, KennyP and boyscout862 have said thanks
#5 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted February 18, 2013 - 12:19 PM
That is no doubt going to have be welded. What method of welding are you going to do.
Dick
Edited by JRJ, February 18, 2013 - 01:31 PM.
#6 Texas Deere and Horse OFFLINE
  • 14,799 Thanks
  • 15,495 posts
Posted February 18, 2013 - 12:20 PM
Daniel, I have seen one that loose. I would get the cracks welded up and then look at adding a couple cross braces, one in front and one behind the Hydro. You will have to make it so the drive shaft and PTO can go through them.
#7 mowinman2 OFFLINE
mowinman2
    Always on the Hunt
  • 198 Thanks
  • 243 posts
Posted February 18, 2013 - 12:21 PM
WOW!!  That would be a great reason for the speed changes.  I cant wait to see the final work you have done and see how much it helps.
#8 olcowhand ONLINE
  • 41,072 Thanks
  • 31,393 posts
Posted February 18, 2013 - 12:26 PM
Yes, I was thinking about making another cross member, as the top of the frame rails has nothing at all to prevent twisting forces from breaking things where they are broken,
#9 coalminer16 OFFLINE
coalminer16
  • 2 Thanks
  • 1 posts
Posted February 18, 2013 - 04:00 PM
I just found this forum from another one. My post may be delayed as I am getting the message that I have to have it approved before it is shown.
One of my two 332's had the cracks where the axle bolts to the frame. Fairly common crack area. My brother who is a professional welder just used the plasma cutter to "grove" out the crack, welded solid and ground it back smooth. The crack can form from loose bolts or other various reasons of use over time. My 332 didn't have evidence of any other implements other then the mower deck.
As far as adding braces-that is good to a point. There is some pretty ugly fixes out there including the one done on my fathers 430 I currenlty am working on. I will end up cutting off the rear of the frame and adding a new section in from  a free frame I had gotten.
And the speed up/slow down. Make sure to check the linkage to the swash plate (input into the tranny pump) as well. And not only will the flexing of the cracks cause the speed up but also loose bolts. My other 332 had loose bolts. They bolt had bad linkage. One had a bolt so thin it was just barely there.
  • olcowhand and JRJ have said thanks
#10 glgrumpy OFFLINE
  • 8,605 Thanks
  • 7,909 posts
Posted February 18, 2013 - 05:44 PM
Once bought a 317 chassis to use drive. It was all floppy in frame where axles go thru. BUT, didn't see a way to just cut a little and slip the frame off the axle. Seems the frame orig just had holes or cut areas and must have been put on before the axle housings were installed??  Someone had tried to fix with angle and bad weld job. Am I not seeing how they were built or ?   Wondering if maybe too much bracing won't just give more problems or breakage of cases or ? if too solid. Would think maybe some flex is kinda built-in and needed? Not certain on that, just wondering.
#11 KennyP ONLINE
  • 38,267 Thanks
  • 45,876 posts
Posted February 18, 2013 - 05:57 PM
Looks like you found the root of the issue. I'm sure you will have it going right again soon!
#12 olcowhand ONLINE
  • 41,072 Thanks
  • 31,393 posts
Posted February 18, 2013 - 06:44 PM
Had a long day with a heifer calving, but I did get some accomplished on the 430.  I am adding 3 1/2" x 1/4" angle iron where the axle tubes bolt.  Where you see the red dots, I will drill & place 7/16" bolts & nuts.  The green marks is where I will weld it in 1" or so increments.  I believe along with repairing the front crossmember, doing this on both sides will be enough to last years without additional bracing.
The right side was broken up really bad.
  • KennyP and JRJ have said thanks
#13 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted February 18, 2013 - 06:59 PM
now i have to check mine , when i go down hill it feels like what you described . i just figured it was the old worn out gears in the tranny .
#14 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted February 18, 2013 - 08:27 PM
The older 300's use a different setup where the axle assembly is welded to a 8" high 1/4" thick U section that forms the rear wall of the frame. This then bolts to the frame rails. When JD switched to the open style rear frame they had to change the axle mounting method. This is good to know if I'm ever looking at one of these tractors in the future.
#15 Cat385B ONLINE
    HAZMAT CAT
  • 13,969 Thanks
  • 10,001 posts
Posted February 18, 2013 - 09:02 PM
Calf and new mooma doing okay?
