Eureka!
4 replies to this topic
#1 OldBuzzard ONLINE
OldBuzzard
  • 6,984 Thanks
  • 4,783 posts
Posted February 18, 2013 - 02:13 AM
I've finally found something I've been wanting ever since I got my first 3-pt hitch. A quick attach system for CAT 0 hitches :dancingbanana:  :dancingbanana: :dancingbanana:
I know that GARY400 has addressed this with a very well built quick hitch, but like all of them with that design, all of your impliments have to have the same distances between the lift pins and top link attachment. That isn't always the case.
I liked the idea of Pat's EZ Change system, but they don't make it in CAT 0.
http://www.greenwellmfg.com/hitch.htm
The only drawback to Pat's is that it does extend the lift arms, and that would lessen the amount of weight you would be able to lift due to the longer length.
I just stumbled on this system, the Carter EZ Hitch:
http://www.carterandsonsllc.com/
Now, it's not perfect either.  While it doesn't extend the length of the lift arm, if does make the attachment point HIGHER.  That means that it won't let the implement to drop as far.  I guess that you could overcome that to some extend with an adjustment of the lift links though.  It's also not as 'automatic' as Pat's, but still better than wrestling with the ball joint on the standard 3-pt.
The BEST thing about the Carted system though is that it's available for CAT 0!!!
http://www.carterand...alog/c6_p1.html
This is definitely going on my MUST HAVE list  :D :D :D
  • Alc, sacsr and boyscout862 have said thanks
#2 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,748 Thanks
  • 4,242 posts
Posted February 18, 2013 - 04:27 AM
Congrates OB! And very interesting Links :thumbs:
#3 JDBrian OFFLINE
  • 9,608 Thanks
  • 14,144 posts
Posted February 18, 2013 - 06:19 AM
That's an interesting alternative but you still have to get off the tractor to deal with the top link and the pins. I like being able to back up to an implement and connect to it without leaving the seat. I use an i match on my compact tractor and wouldn't be without it.
#4 OldBuzzard ONLINE
OldBuzzard
  • 6,984 Thanks
  • 4,783 posts
Posted February 18, 2013 - 09:10 AM
The imatch, and others like it are great...IF your equipment fits the hitch.
Not all 3-pt equipment has the same dimensions, so while a little more work, the ones I listed will work with any 3-pt implement in it's  CAT range.
#5 JDBrian OFFLINE
  • 9,608 Thanks
  • 14,144 posts
Posted February 18, 2013 - 10:53 AM
Some of the generic quick hitches have an adjustable top link fixture but the imatch does not.
