Going To Pick Up A Freebie Mf12h In The Morning.
115 replies to this topic
#76 HowardsMF155 OFFLINE
  • 3079 Thanks
  • 3084 posts
Posted February 21, 2013 - 08:04 AM
There was a revision of the drive train on those hydros.  Is it possible the drive belt was changed because of that?
  • IamSherwood said thank you
#77 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted February 21, 2013 - 08:18 AM
Ahhh. Possible.
#78 KennyP ONLINE
  • 50938 Thanks
  • 52621 posts
Posted February 21, 2013 - 08:31 AM
That could explain things! Where's the MF guru's? :bigrofl:
#79 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted February 21, 2013 - 09:32 AM
Ahhh. Possible.
Both early & later versions called for the identical belt in the Agco books.
#80 HowardsMF155 OFFLINE
  • 3079 Thanks
  • 3084 posts
Posted February 21, 2013 - 12:17 PM
Now Daniel,, I had a good thing going there and you just spoiled it!
:bigrofl:  :bigrofl:  :bigrofl:  :bigrofl:
#81 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted February 22, 2013 - 08:06 AM
Yesterday morning I picked up a new 84", and 83".
Then I went to one of my carcass, and pulled the belt off.
It was a 83", and in good shape. Same length as the new
83" Dayco I'd just picked up.(when held against each other)
 I put the used 83" on. Looks to
be the right fit. I'll see later today when I get it running again.
I also got the neutral return cam back together. I had to make
up a step bushing that fits into the tower side because I melted
the OE bushing with the torch, when I tore it down.
Also drained the engine "Oil". :(  :(
I've never seen anything like it before.
It came out, like a half melted Gummy Bear.
I've been flushing it with varsol. Is there something better I should be doing?
Also put some new rubber on the back. One of the rears that was on it leaked.
  • MH81, KennyP and boyscout862 have said thanks
#82 KennyP ONLINE
  • 50938 Thanks
  • 52621 posts
Posted February 22, 2013 - 08:16 AM
Now you can take the new belts back! I think that 'oil' has see better days! I think I would run a bit of Marvel Mystery oil in with the first new oil and change pretty quick again. Should help flush out some of the nasty stuff!
  • IamSherwood and boyscout862 have said thanks
#83 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted February 22, 2013 - 08:22 AM
Good news on the fit for the belt.
"Half melted gummy bear" LOL. Great mental image. This is the heated shop, right? I mean, that engine isn't 20 below or anything, is it?
As for clean out, varsol (zippo lighter fluid) should cut thru almost anything... But I usually use warm kerosene... Lower flash point.
For the few bolts a pan gasket, and the extra couple hours, have you considered doing an exploratory surgery & cleaning? I suppose if it ain't broke, don't fix it...
#84 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted February 22, 2013 - 08:30 AM
Thought about tearing it apart, but I think I'll see how runs on the ground first.
At this point, I don't even know yet, if the hydro is any good.
So far the only money I've spent is a spark plug, and cleaning toxins.
I don't know if we can get MMO up here, so I'll flush more with
varsol, and add Rislone to the oil change.
Yes, the shop is warm. That stuff was almost like Jello.
Who does that to an engine? :(
#85 1978murray OFFLINE
1978murray
    diesel mechanic
  • 609 Thanks
  • 1165 posts
Posted February 22, 2013 - 08:38 AM
i wondering if the guy didnt run out of engine oil and figured stp would work.
#86 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted February 22, 2013 - 08:43 AM
Well, whatever it was, it's coming out of there.
#87 KennyP ONLINE
  • 50938 Thanks
  • 52621 posts
Posted February 22, 2013 - 08:53 AM
Rislone is good. You can also use a small amount of ATF. Main thing is to flush to engine. Let it run and warm up real good and drain it back out. The rings might be stuck in it with that goop in the crankcase.
#88 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted February 22, 2013 - 09:10 AM
Yes, if everything else works good, I plan on changing out the oil a few times
in short order.
Thanks for the ATF tip Kenny.
#89 boyscout862 ONLINE
  • 14946 Thanks
  • 9929 posts
Posted February 22, 2013 - 12:52 PM
I saw that in the late 60s where some people put extra STP oil into their big engines and ran them hard. When the engine was shut down and cooled it wouldn't start again. When the oil pan was dropped it was full of "grease". Extra is not always better.
The engine in my HD6G had water in it. I'll be dropping the pan from it soon. No fun but its better than the consequences. Good Luck, Rick
Edited by boyscout862, February 22, 2013 - 03:11 PM.
#90 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1090 Thanks
  • 1284 posts
Posted February 22, 2013 - 07:35 PM
:bigrofl: The ONLY thing worse than having melted Gummy Bears in your engine is to have Dancing Gummy Bears stuck in your computer monitor. :bigrofl:
  • MH81 and IamSherwood have said thanks
