Going To Pick Up A Freebie Mf12h In The Morning.
115 replies to this topic
#46 KennyP OFFLINE
  • 51093 Thanks
  • 52671 posts
Posted February 19, 2013 - 07:04 AM
Looks good, Will! Right front could use a little air, looks a bit low! Glad you have it running, hope to see pics of you driving it around soon!
  • IamSherwood said thank you
#47 ckjakline OFFLINE
ckjakline
  • 1185 Thanks
  • 1176 posts
Posted February 19, 2013 - 04:51 PM
That was definately worth the trip.It's got alot of potential.Good luck with it.Keep us posted.
#48 Texas Deere and Horse OFFLINE
  • 15112 Thanks
  • 15570 posts
Posted February 19, 2013 - 06:06 PM
Great looking Hydro Will, The electric lift looks a lot like the WH C-Series lift that was an option.
#49 daytime dave OFFLINE
  • 5472 Thanks
  • 6779 posts
Posted February 19, 2013 - 06:22 PM
Looks like a good deal Will.  The price was surely right.   :thumbs:
#50 UncleWillie OFFLINE
  • 16501 Thanks
  • 9061 posts
Posted February 19, 2013 - 08:31 PM
Seeing that tractor brings back so many memories of my grandfathers MF12. I really want one.
#51 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted February 20, 2013 - 09:12 AM
I got to spend some time on this yesterday. It has a few issues, but they can be fixed.
My intention for this machine, is to keep it around as a trailer puller, and as a toy
for the younger generation to ride, when we get company. They see all my tractors
and want to ride one. Well, they're not going to get one of the restored ones.
So, I have to make sure this thing is safe for them.
The issues:
Entire brake band/mount/spring is missing. I have that on a carcass burried
in the snow. Might try to get that today.
The clutch/brake pedal, was not returning the hydro lever to neutral. As suspected, the
Cam roller lever assembly that is activated by the Actuator Cam assembly was bent.
I've found this same situations on 2 other 12H's. I'm not quite sure how this gets
accomplished, but it seems to be a weak point in the design. Here you can see
the Cam assembly, and lever. The lever actually
sits up tight against the tower when put back together. It's a bear of a job to
get that lever out of there, but had to be done.
What I'll do now, is brace the lever as I did on the other 2, after I straighten it.
  • MH81, KennyP and Moosetales have said thanks
#52 KennyP OFFLINE
  • 51093 Thanks
  • 52671 posts
Posted February 20, 2013 - 09:23 AM
Looks like a good fix. The bending is probably lack of lube and rust build up.
#53 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted February 20, 2013 - 09:27 AM
That brace should take care of that!  Should have been built stronger, but like Kenny said, likely would never happen if kept lubed & rust free.
#54 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted February 20, 2013 - 09:30 AM
Oh ya, the other safety issue I found, which I decided to fix too.
The front axle pivot bolt had no nut, and was half way out.
  • Amigatec said thank you
#55 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted February 20, 2013 - 09:37 AM
It's not an issue at all.......till it completely falls out!   :D
#56 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2029 Thanks
  • 3172 posts
Posted February 20, 2013 - 09:47 AM
That could pose a bit of a problem.
#57 HowardsMF155 OFFLINE
  • 3079 Thanks
  • 3084 posts
Posted February 20, 2013 - 09:51 AM
Wow Will, You have really beefed that up.  One of my two hydros had the same problem, I didn't think about trying to weld that kind of brace on.  I wonder if part of the problem is people leaving their hands on the control lever and adding resistance to the action of the lever.  EDIT: or if the hydro neutral is out of adjustment and they crank on the handle to get it to stop moving.  END EDIT  Anyway, I certainly know what to do now it it happens again!
Edited by HowardsMF155, February 20, 2013 - 09:53 AM.
#58 Amigatec OFFLINE
Amigatec
  • 2029 Thanks
  • 3172 posts
Posted February 20, 2013 - 09:59 AM
I had kind of the same problem with my 10G the pin on the clutch pedal had snapped off, I drilled it out and replaced it with a bigger pin.
#59 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted February 20, 2013 - 07:18 PM
I agree with Kenny, and Dan, that lack of lube would be the biggest factor. If that
roller can't turn, it'll just bind up, and if wrong cowboy is on there, thinking he's
kick starting a motorcycle, that lever will bend in no time.
And, being greasing it, isn't mentioned in the manual, and it's hidden, that's
the outcome. I think it's called planned obsolesence. Haaaa. Didn't we show those
engineers. We're still driving these things.
#60 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3494 Thanks
  • 3384 posts
Posted February 20, 2013 - 07:31 PM
Man great deal Will!  That is a very nice looking FREE MF!
