Sleeve Hitch
6 replies to this topic
#1 paulka86 OFFLINE
paulka86
  • 2 Thanks
  • 5 posts
Posted February 17, 2013 - 05:20 PM
hey guys im new to this form but i got some questions. i bought a sleeve hitch for my craftsman tractor model no. 917.251.480 it had no sleeve hitch when i got it but there are some of the same modles that have one . my problem is that i can not get it hooked up. it cam with an actuator to power it and it came off a tractor with the model number 917.255.913. i have every thing hooked on the back of the tractor but i cannot figure out the rest so im hoping that yall can help me out. the sleeve hit model that i have is 917.252.312
  • bgkid2966 and boyscout862 have said thanks
#2 boyscout862 ONLINE
  • 12,812 Thanks
  • 9,151 posts
Posted February 17, 2013 - 06:21 PM
Welcome to GTT. I'm not familiar with your tractor but the hydraulic lift mechanism is usually inside the tractor. Some one else will be by to help.
  • paulka86 said thank you
#3 MH81 OFFLINE
Posted February 17, 2013 - 06:23 PM
Somewhere in the back of my dusty mind, I remember reading that some actuators wouldn't fit physically in some of those tractors. That could be your problem or possibly the actuator takes the place of the long rod. Keep in mind there has to be at least one slotted hole involved to allow the implement to float.
I think that rod you have will actually work with the OEM lift handle.
#4 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted February 17, 2013 - 06:25 PM
Welcome to the forum! Sit down with a cup of your favorite beverage and stay a spell!!
Some body will be along that has more knowledge on the sleeve hitch. I am unable to assist.
Geno
#5 paulka86 OFFLINE
paulka86
  • 2 Thanks
  • 5 posts
Posted February 17, 2013 - 06:28 PM
the actuator came off a tractor with the model  number 917255913 the actuator and the sleeve hitch is there a manual for how the actuator would hook up?
#6 boyscout862 ONLINE
  • 12,812 Thanks
  • 9,151 posts
Posted February 17, 2013 - 06:55 PM
Did you check our manuals section? You can download a few manuals a day for free.
#7 glgrumpy OFFLINE
  • 8,602 Thanks
  • 7,906 posts
Posted February 17, 2013 - 07:31 PM
Maybe one hitch fits many models and not all use same parts. think drawiing shows a link to go to say a manual lift handle. I'm kinda thinking the electric lift actuator stays on outside of hitch right on back. You need special switch and wiring to hook up to your dash, which may have come in new kit. With this actuator, you wouldn't use the long link arm either.  Sears wanted $350 to put one on a new tractor if I bought it, maybe it's a lot of work??  Seems you need assembly or owner's manual.
