Ive got a problem with a k341 engine driven pto
7 replies to this topic
#1 Tom Hefner OFFLINE
Tom Hefner
  • 1 posts
Posted September 24, 2010 - 11:05 AM
Im rebuilding a 1650. I am putting a K341 on it. I have what appears to be a slip clutch driven by a pulley about 8" diameter and it has a pulley about 4" diameter. I cant remove it. Ive removed 2 set screws but it still wont come off. Can anyone tell me what it is for and how to remove it. Will valve springs from a K161 be sufficient substitute on a K301. Thanks for any help. Im new at this. Ive almost finished renewing an Original model, putting a 12hp Kohler in it for more power. :confuse: Tom
#2 coop OFFLINE
coop
  • 24 Thanks
  • 103 posts
Posted September 24, 2010 - 11:25 AM
If I remember correctly there was a thread on this. Underneath the set screws are two more screws.
#3 mjodrey OFFLINE
Posted September 24, 2010 - 12:11 PM
Tom Hefner:welcometogttalk:glad to have you here.
#4 olcowhand OFFLINE
  • 43,180 Thanks
  • 32,014 posts
Posted September 24, 2010 - 08:09 PM
Yes, the 3 set screws lock against 3 more pointed set screws that lock behind the bearing. These are spaced evenly behind the pulley groove. Gotta get all 6 out 1st. Never had a K161, but I'm comfortable saying you do not want to use those springs in a 301 even if they would fit.
#5 jay nesbitt OFFLINE
jay nesbitt
  • 1 Thanks
  • 4 posts
Posted September 28, 2010 - 04:32 PM
I just joined and I just finished rebuilding my PTO clutch. COOP and OLCOWHAND above is correct; there are locking set screws above the retaining set screws three places. Then use a slap hammer or other hammer to "bump " it off. IE: Bump, bump, then turn clutch/crank about 1/3 turn then repeat until it is off the bearing.
hope this helps,
Jay
#6 caseguy OFFLINE
  • 1,629 Thanks
Posted September 28, 2010 - 06:17 PM
:wave: Tom Hefner, :wave: jay nesbitt! Welcome to the forum! Glad to see you're jumping right in there! That's the spirit that makes this a great site!
#7 Bolens 1000 OFFLINE
  • 15,559 Thanks
  • 18,320 posts
Posted September 28, 2010 - 07:37 PM
:ditto: :ditto:
#8 mjodrey OFFLINE
Posted September 29, 2010 - 05:23 AM
jay nesbitt :welcometogttalk:
