How To Fix Gas Tank Leak
9 replies to this topic
#1 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted February 16, 2013 - 09:51 AM
Ok, I just found out this morning my gas tank has a small leak at the seam. Is there a way to fix this? This is the 5 horse I just got on the David Bradley and I was just wondering if there was a quick fix I could try.
#2 boyscout862 OFFLINE
  • 13,552 Thanks
  • 9,427 posts
Posted February 16, 2013 - 09:57 AM
You have a number of options. Solder, Epoxy, or a liquid liner in the tank. I've had limited success with epoxy. I'll try the liquid liner this spring on 5 tanks that I've got. Good Luck, Rick
  • HDWildBill said thank you
#3 MH81 OFFLINE
  • 29,979 Thanks
Posted February 16, 2013 - 10:00 AM
If its metal and we are talking a small leak (seep), I would try the liner. You'll have a couple of days with dry time, but I think it will be your best bet. What ever brand, read and follow the directions exactly.
#4 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted February 16, 2013 - 10:18 AM
Please let us know if you try the liner. That is what I would use but I have not had the chance to try it yet.  Good luck Rick!
#5 HDWildBill OFFLINE
  • 8,984 Thanks
Posted February 16, 2013 - 10:30 AM
Many, Many, Many moons ago when I was a teen, a friend of mine had a small leak in his gas tank on his car.  An old timer told us to use bar soap as a temp fix.  It worked, every 4 or 5 days he would get under his car and scrap some soap over the hole.
A more permanent fix would be as stated above, but if you just need a quick temp fix the soap may help.
  • boyscout862 and superaben have said thanks
#6 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted February 16, 2013 - 12:36 PM
I love the soap idea.  That goes in my book of great makeshift ideas to have when I need it!  You have to snatch that knowledge from the old timers before they go.
I used Eastwood's sealer on my Farmall tractor tank.  It will produce much more than you need for a Bradley, though.  Maybe you could seal a couple others while you are at it!
Try a radiator shop: my local one sealed a few Gravely tanks for me very cheaply.  He even painted it!
Ben W.
  • MH81, Alc, HDWildBill and 1 other said thanks
#7 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted February 16, 2013 - 02:57 PM
I believe I would also take the tank to the radiator shop, I read a sign once on the building of a radiator shop that read 'the best place in town to a leak'.
Dick
#8 Grumpy OFFLINE
Grumpy
  • 747 Thanks
  • 623 posts
Posted February 16, 2013 - 03:16 PM
I have had good luck with the gas tank sealer you can by at the auto parts house. Its about .5 in. dia. and abou 3in. long. also beleave it or not, Bondo works well. Just make sure the surface is clean.
#9 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted February 17, 2013 - 05:15 AM
If the tank is clean inside, solder would do the trick, if its rusty, I would try RedKote to seal it.
#10 nade-em OFFLINE
nade-em
  • 202 Thanks
  • 171 posts
Posted March 01, 2013 - 10:36 PM
http://shop.advancea...m=plastic metal
I used this on my tiller gas tank(pin holes) and it worked great .
