Bolens Tube Frame Mid Mount Grader Blade
49 replies to this topic
#16 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted February 16, 2013 - 06:17 PM
I remember reading somewhere  there were different linkages available for the Hydrostatic Models and Gear driven models.
  • blackjackjakexxix and MyBolens1053 have said thanks
#17 MichBolens OFFLINE
MichBolens
  • 32 Thanks
  • 92 posts
Posted February 16, 2013 - 06:38 PM
I've got 2 of them, the frames are the same, one is just a few inches longer.
#18 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3727 Thanks
  • 2367 posts
Posted February 16, 2013 - 07:29 PM
Maybe one is for the tube frame an the other for the large frame
  • MyBolens1053 said thank you
#19 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted February 17, 2013 - 09:26 PM
There are a few good pics of that blade in this post http://gardentractor...s-grader-blade/
  • blackjackjakexxix, MichBolens and MyBolens1053 have said thanks
#20 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3727 Thanks
  • 2367 posts
Posted February 18, 2013 - 12:07 AM
Wow,Thanks for the great info,Rick
#21 LPBolens OFFLINE
LPBolens
  • 1461 Thanks
  • 979 posts
Posted February 18, 2013 - 08:38 AM
Got some pics of it,it does have manual angle on it,locks in place with a pin
That one was made by Hydro-Speed
#22 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3727 Thanks
  • 2367 posts
Posted February 18, 2013 - 10:15 AM
Thanks Doug
#23 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted March 20, 2016 - 05:54 PM
I still have not figured out how to hook mine up either. It is referenced in one of the links in this thread. I need to look into that again I'd love to hook it up to my 1556.
#24 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted March 20, 2016 - 07:35 PM
Does anyone have all the brakets for the hydro seed TF one? I just got one it also has the rake part
#25 LPBolens OFFLINE
LPBolens
  • 1461 Thanks
  • 979 posts
Posted March 21, 2016 - 10:08 AM
I think I have all of the correct pieces to mount the Hydro-Speed blade on a Tube Frame in all of the possible configurations. I will try to dig them out and take pics for you, Sam. I might be missing the triangular piece that connects the blade frame to the lift assembly.
Edited by LPBolens, March 21, 2016 - 10:14 AM.
#26 LPBolens OFFLINE
LPBolens
  • 1461 Thanks
  • 979 posts
Posted March 21, 2016 - 04:58 PM
Here are some more pics of the Hydro-Speed 3-position blade for the Tube Frames. I did have the triangular piece that gets attached to the lift lever in two spots. One hole goes over the pin on the side of the tractor lift lever, and another gets bolted to the upper bolt on the same lift lever. My triangular piece looks to be homemade but does follow the general shape of the OEM piece. It turns out the one piece that I do not have is the short connector from the triangular piece down to the blade bracket when it is mounted under the tractor. I also do not have the scarifier piece that can be mounted to the blade, although my blade does have the mounting holes drilled in it.
The two rectangular brackets are sized slightly differently. One is wider than the other. The wider one is used to attach the blade to the rear axle tabs when the blade is used in the rear or is mid-mounted. That is the one that is mounted to the blade in the pics. The narrower one is used to attach the blade to the front axle tabs. Although I have not mounted this attachment on a tractor, I am assuming that the long bars are used as required as part of the blade lifting mechanism.
Edited by LPBolens, March 21, 2016 - 04:59 PM.
  • Bolens 1000, Bruce Dorsi, blackjackjakexxix and 1 other said thanks
#27 AA Hayes OFFLINE
AA Hayes
  • 356 Thanks
  • 311 posts
Posted March 21, 2016 - 06:16 PM
WANT!!
#28 teapot OFFLINE
teapot
  • 4 Thanks
  • 9 posts
Posted March 22, 2016 - 08:09 AM
 Well I have been looking for one and need one for some job so I'm making one as close to specs. as I can to fit a 1476. My blade will have to be 6' so it will clear the high floaters without hitting them. It will be a manual  three positions setup. Should be fun!!   thanks
  • MyBolens1053 and AA Hayes have said thanks
#29 Chubien OFFLINE
Chubien
  • 648 Thanks
  • 399 posts
Posted March 22, 2016 - 08:31 AM
Too bad this is not being reproduced anymore, it's probably one of these attachments that everyone wants but that few are willing to fork out the $$$ for.
  • blackjackjakexxix, MyBolens1053 and AA Hayes have said thanks
#30 AA Hayes OFFLINE
AA Hayes
  • 356 Thanks
  • 311 posts
Posted March 22, 2016 - 09:52 AM
I would fork out the cash if I could find one for my LF or have one build well.
