Winch Mounting- Ideas?
18 replies to this topic
#16 pigsitter OFFLINE
pigsitter
    enjoyin the livin part of life!
  • 1,227 Thanks
  • 1,083 posts
Posted February 16, 2013 - 06:45 PM
  For skidding logs I think a log skidding arch would actually make life simpler.
Good advice! It's much easier pulling logs when you get the front end of the log in the air so that it doesn't dig into the ground.
#17 icpik OFFLINE
icpik
  • 21 Thanks
  • 38 posts
Posted February 16, 2013 - 07:44 PM
One more thing on the safety side that has been eluded to, but not specifically stated.  When a cable snaps, it becomes a decapitator.  When a chain snaps, it just drops.  Often someone using a cable will drape a chain or rope across the cable multiple times to dissipate energy if the cable snaps.
Don Hayes
#18 IamSherwood OFFLINE
  • 8,382 Thanks
  • 7,696 posts
Posted February 16, 2013 - 07:54 PM
Will, if I had a guide in the front to keep the cable straight, would it not be the same as if the winch was in the front?
Yes Ryan that will work. Myself, I wouldn't be a fan of feeding the cable through under the tractor.
But then, I'm not as young as you. You can probably still bend down. :D
  • HDWildBill said thank you
#19 KennyP ONLINE
  • 32,251 Thanks
  • 42,033 posts
Posted February 17, 2013 - 07:26 AM
Who bends anymore? I just lay down under it, then use a winch to get back up!
