Less Mess Paint Can Spout
13 replies to this topic
#1 Nato77 ONLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted February 15, 2013 - 12:53 PM
I don't know if anyone has put this on here already, but here is a little trick to help not make a big mess when pouring paint from a can.
A guy showed me Years ago a way to keep more paint in the can verses all over the place (table, hands, sides of the can).
  When you open a new (or old) can of paint its pretty full. To keep things a little neater I just take the lid off and take a small punch (sharp nail or screw works too) to make a bunch of holes in the lowest part of the top of the can.
Then take some 2" masking tape and put around the top edge of the can. Next put another piece of tape onto the first one.
When you pour the paint out of the can you can see it doesn't run down the side of the can.
Then set the can back down to let the paint run through the holes you put in the top of the paint can. As you see no paint on the side of the can. When you put the lid back on the holes also help to keep paint from pushing out between the lid and the can.
Hope this helps you not make a mess. It sure has helped me.
  • Gtractor, jms180, Texas Deere and Horse and 12 others have said thanks
  • 14,800 Thanks
  • 15,495 posts
Posted February 15, 2013 - 01:17 PM
Thanks, I had not seen that before, great paint tip !!
  • Nato77 said thank you
#3 Nato77 ONLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted February 15, 2013 - 01:30 PM
I was just thinking, you might have to add one for row of tape for the gallon cans. I usaully don't have to, but if you just need a small amount out of the can 3 rows would work the best.
#4 HDWildBill OFFLINE
  • 8,975 Thanks
Posted February 15, 2013 - 01:37 PM
I also had not heard about this trick.  Thanks for sharing this with us.  :thumbs:
#5 boyscout862 ONLINE
  • 12,839 Thanks
  • 9,162 posts
Some places sell a plastic lip that clips onto the can to help.
  • Texas Deere and Horse, HDWildBill, Nato77 and 1 other said thanks
#6 Nato77 ONLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted February 15, 2013 - 02:02 PM
I've seen them before. I figure its cheaper buying a roll of tape (which lasts me about a year). No clean up with tape either.
Edited by Nato77, February 15, 2013 - 02:03 PM.
  • HDWildBill and boyscout862 have said thanks
#7 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted February 15, 2013 - 02:12 PM
  I've had the plastic lips for several yrs and love them. Works on gallon or quart cans.
                                                Mike
  • HDWildBill, boyscout862 and Nato77 have said thanks
#8 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,313 Thanks
  • 4,949 posts
Posted February 15, 2013 - 03:03 PM
If you get POR-15 paint in that groove and then put the lid back on it will never open again.  Dried POR is stronger than the steel of the can!  :(
#9 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,769 Thanks
  • 4,261 posts
Posted February 15, 2013 - 03:07 PM
easy and clever, thanx for sharing
#10 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted February 15, 2013 - 03:12 PM
I did pick up a tip on TV last night. If masking tape gets old and stiff and rips when you try to unroll it, put it in the microwave for 15 seconds. It softens up the glue. I have not tried it yet, but it sounds good
  • HDWildBill, boyscout862, Nato77 and 1 other said thanks
#11 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted February 15, 2013 - 03:13 PM
I never used POR-15. Didn't like that it got so hard and I can't remember if that was the stuff that would fade in the sun (low UV protection) or not. My paint reps are always trying to get me to use other products, but I like what I'll using now so why change. Do alot of semi frames which up here last about 4-5 years. The blasting guy hates it when the paint don't come off.
#12 boyscout862 ONLINE
  • 12,839 Thanks
  • 9,162 posts
Posted February 15, 2013 - 04:44 PM
I'm going to show my ignorance or senility: What is POR-15?
#13 Alc ONLINE
  • 6,884 Thanks
  • 7,459 posts
Posted February 15, 2013 - 04:49 PM
Here's their site  I.ve had very good luck it
http://www.por15.com/
#14 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted February 15, 2013 - 06:32 PM
What!! The mess on the side of the can is good! It helps label what color's in the can!
No, seriously, that's a great tip I will be using in a few days.  I wish I could double thank your post... can we do that, Kenny??
Ben W.
