Brinly Planter
19 replies to this topic
#1 66jd1020 OFFLINE
66jd1020
  • Validating
  • 7 Thanks
  • 10 posts
Posted February 15, 2013 - 10:53 AM
I have this older Brinly planter that was given to  me. I cannot find a model number.  The front plow sweep is mounted different than the other Brinly planters I have seen.  It is missing the hitch plates and I only have one seed plate, so it would be helpful to get a model number.  Thank ou. IMG_0004.JPG
#2 boyscout862 ONLINE
  • 13,440 Thanks
  • 9,385 posts
Posted February 15, 2013 - 11:10 AM
Welcome to GTT. Check the manuals section  http://gardentractor..._key=all&st=120 for three free downloads per day.
Someone will be along to help you soon.
Edited by boyscout862, February 15, 2013 - 11:14 AM.
#3 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted February 15, 2013 - 11:21 AM
Welcome to the forum. Cool planter and the price was right. Good luck on figuring it out.
#4 OldBuzzard ONLINE
OldBuzzard
  • 7,082 Thanks
  • 4,809 posts
Posted February 15, 2013 - 12:58 PM
What do you mean by "It is missing the hitch plates"?
All I see that is missing is the row marker.
As for the hitch, that looks like a standard sleeve hitch setup.
Edited by OldBuzzard, February 15, 2013 - 12:59 PM.
#5 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted February 15, 2013 - 01:02 PM
:ditto:
Dang computer got stupid. Sorry for the double post.
Edited by Nato77, February 15, 2013 - 01:06 PM.
#6 OldBuzzard ONLINE
OldBuzzard
  • 7,082 Thanks
  • 4,809 posts
Posted February 15, 2013 - 01:17 PM
Been there and done that :D :D :D :bigrofl:  :bigrofl:  :bigrofl:
#7 66jd1020 OFFLINE
66jd1020
  • Validating
  • 7 Thanks
  • 10 posts
Posted February 15, 2013 - 02:38 PM
In the first image (downladed from another post), the hitch plates are outlined in red. If you will notice in my original post image,those are missing. The actual hitch is being propped up by  a tent stake.
When I  first picked up the planter, the hitch was not attached to the frame. My guess is that somewhere along the line somebody  attempted to bolt the planter on a cultivator frame. In the process, losing some parts.
In the second photo below (my planter), you you will notice a welded horizontal  rod in the frame in place of  two of the rear bolt holes that are used in mounting the hitch paltes. I will probably end cutting out that rod once I get the hitch plates.
  • Nato77 and jdnut have said thanks
#8 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted February 15, 2013 - 03:25 PM
Now I see what you mean with the parts missing. Wouldn't think they would hard to make. But does yours have the 2nd hole back farther? Can't time from the pics.
#9 66jd1020 OFFLINE
66jd1020
  • Validating
  • 7 Thanks
  • 10 posts
Posted February 15, 2013 - 03:49 PM
No, it does not have the second hole. It has a  welded rod instead.   I agree the plates should not be hard to make. Before I removed the rod and drill holes in the frame,  I wanted to see the original hitch plate configuration first, just to make sure I wasn't missing anything.
#10 MH81 OFFLINE
Posted February 15, 2013 - 06:13 PM
I have a planter of the same vintage, hd to go find that thread to see what was different. http://gardentractor...er/#entry151591
The front sweep on yours is an added piece, and I believe it is off a cultivator. Probably someone trying to make it work better in hard ground... Might work really well, actually.
Nice unit, did you get any other plates with it?
  • 66jd1020 said thank you
#11 1967bolens collector OFFLINE
    Deceased
  • 655 Thanks
  • 1,441 posts
Posted February 16, 2013 - 05:03 AM
i also have one these are kinda hard to find, they want as much for the seed plates that i paid for the whole planter im going to restore mine this year sometime im going to get 2 new hoppers made and lids
#12 drbish ONLINE
drbish
    Collecter
  • 1,571 Thanks
  • 1,370 posts
Posted February 16, 2013 - 05:11 AM
Just added this to the manual section.It has the hitch adapter drawing
http://gardentractor...ter-fertilizer/
  • MH81, OldBuzzard and 66jd1020 have said thanks
#13 66jd1020 OFFLINE
66jd1020
  • Validating
  • 7 Thanks
  • 10 posts
Posted February 18, 2013 - 02:27 PM
MH81,
Thanks for that post. I only have  one seed plate,  #28.
Did you ever figure out what model it is?
#14 66jd1020 OFFLINE
66jd1020
  • Validating
  • 7 Thanks
  • 10 posts
Posted February 18, 2013 - 02:37 PM
new restorer,
thank you for your post. Unfortunately, I cannot download that one today- too  many already.
  • superspeedex said thank you
#15 MH81 OFFLINE
Posted February 24, 2013 - 05:26 PM
I finally got back in there to the planter.
The hitch is exactly like yours and has the second rod welded in there.
the plates are to keep the planter from moving to far on the hitch while keeping the thing floating to acheive proper operation.
the planter itself is not able to be gotten out at this point, but the pin could be pulled and the plates measured.
