Oil Filter On My Gt275 ?
5 replies to this topic
#1 backwoods OFFLINE
backwoods
  • 2,629 Thanks
  • 2,818 posts
Posted February 15, 2013 - 10:39 AM
what other oil filter will fit other then the factory replacement if any and what oil do you recomend?
#2 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted February 15, 2013 - 11:00 AM
I'm not sure on the oil filter but I'd see if Napa has a replacement. I don't normally use JD oil but tend to use whatever I can get on sale. I have a case of Castrol GTX I got on sale and have been using that where 10w30 is required. For 30w in the older tractors I have some Amsoil synthetic that is rated to replace 30w. I'm going to try that this year.
#3 Kyocum OFFLINE
Kyocum
  • 299 Thanks
  • 424 posts
Posted February 15, 2013 - 11:03 AM
As far as oil filters go if you are not going to use OEM then I would opt for a Wix or Napa filter. As far as oil I would use whatever oil is recommended. Oil is the life blood of that machine so don't skimp. Use a good name brand oil meeting the specs of the owners manual.
Edited by Kyocum, February 15, 2013 - 11:05 AM.
#4 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted February 15, 2013 - 11:57 AM
I use a synthetic  Mobil 1, you choise of weights. 5w-30 sounds like a good to me, but i'm not sure the weight I am using right now-I would have to look at the bottle.
 As far as filters I will be changing to Wix if I can find one at a good price, I am not useing a JD, but there are other brand also.
Dick
Edited by JRJ, February 15, 2013 - 03:21 PM.
#5 Kyocum OFFLINE
Kyocum
  • 299 Thanks
  • 424 posts
Posted February 15, 2013 - 04:36 PM
Dick
JRJ Napa and Wix are made by the same company.
  • JRJ said thank you
#6 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted February 15, 2013 - 05:18 PM
If they both are made by the same company then that goes to show 'I have good taste'.
Dick
