Looking At A 78 G14 Today. Anything I Need To Look Out For?
#1
OFFLINE
Posted February 15, 2013 - 08:30 AM
#2
ONLINE
Posted February 15, 2013 - 08:54 AM
Generally if the tractor is not running it drops the price down quite a bit IMO. There could be other things wrong besides a solenoid that may not be visible, such as worn out rod or bad rings/ valves.
A few things to start you off with:
What condition is the tractor in?
Original paint?, Has it had any modifications done on it?
Is the engine/ transmission leaking any oil?
What shape are the clutch discs/ brake pads in? This could give you an idea of how worn the transmission gears may be if the discs/ pads are really worn and not working.
#3
ONLINE
Posted February 15, 2013 - 09:23 AM
That tecumseh engine is notorious for the ignition being very expensive to fix if it doesnt work. You also should consider the value of the attachments that come with it. When working right they are great tractors. Download the manual from this site and get familiar with the tractor. Good Luck, Rick
#4
OFFLINE
Posted February 15, 2013 - 09:30 AM
I would use jumper cables to jump the starter. It may not start do to bad gas/dirty carb if it's been sitting awhile. Even if it doesn't start you can at least check for spark,compression and listen for bad internals. Good luck
- boyscout862 said thank you
#5
OFFLINE
Posted February 15, 2013 - 10:01 AM
All good points stated above,you should be able to by pass the selenoid and start it
Edited by blackjackjakexxix, February 15, 2013 - 10:02 AM.
#6
OFFLINE
Posted February 15, 2013 - 10:07 AM
#7
OFFLINE
Posted February 15, 2013 - 10:31 AM
#8
OFFLINE
Posted February 15, 2013 - 10:44 AM
To jump the starter you need a confirmed good battery, even the one in your car will do. Hook the cables to the battery first, then connect the positive cable to the starter. There should be only one post on the starter with a fairly heavy wire/cable going to it, hook the other end of the positive cable to this post or to the other end of the heavy wire/cable where it connects to the solenoid. Then when you are ready to turn the engine over just connect the negative cable to a good ground on the tractor (head bolt, frame etc.). When you touch the negative cable to ground it will spark at first so make sure it is away from batteries or any combustibles. Also make sure the tractor is not in gear, all pto's/attachments are off and have a plan to shut it down if it should start. I suggest being ready to pull the plug wire, you don't know if the ignition switch is functional. This is the method I use but it may not be the best, others may have better/easier methods.
#9
OFFLINE
Posted February 15, 2013 - 11:07 AM
Good luck getting it. It sounds like it could be a very nice tractor.
#10
OFFLINE
Posted February 15, 2013 - 11:15 AM
#11
OFFLINE
Posted February 15, 2013 - 06:17 PM
- sacsr and boyscout862 have said thanks
#12
OFFLINE
Posted February 15, 2013 - 06:58 PM
You need to be careful listening to Ole Buzzard. He is a little crazy about Bolens and believes that all of them are worth saving.
Oh, I guess we all think that. Nevermind.
Great job picking up the G14 your going to love it.
Ole Buzzard just kidding
- OldBuzzard said thank you
#13
OFFLINE
Posted February 15, 2013 - 07:46 PM
Mike, I take it you got the freewheeling pin out OK?
Mike's G14 has something on it that 99+% of other Bolens TFs don't have...a brake on the PTO that stops it from spinning when you disengage it.
That particular feature was only on the 1978 G11 and G14.
I'll be looking forward to pics, and later, a video of it running
#14
OFFLINE
Posted February 15, 2013 - 07:52 PM
- OldBuzzard, Texas Deere and Horse and sacsr have said thanks
#15
OFFLINE
Posted February 15, 2013 - 07:55 PM
Glad to hear you found a good G T. I'll be waiting to see some pictures of her !
