Need Bevel Gear On Starter
19 replies to this topic
#16 Kentrails OFFLINE
Kentrails
  • 13 Thanks
  • 52 posts
Posted March 06, 2013 - 09:56 PM
I need to rebuild the carb and adjust valves. Can anyone recommend a carb kit, and instruction on the valve adjust?
#17 boyscout862 ONLINE
  • 13,691 Thanks
  • 9,475 posts
Posted March 07, 2013 - 09:04 AM
You can download the manual here for free in the manuals section. You can get the carb kit at NAPA or order it from one of our sponsors. When you remove the breather that covers the valves you may need a new gasket. Depending on which engine there is a good chance that you will have to remove the head. Read the manual first, then try the valves. If the valves are okay you can save a lot of work. If they are not, plan on a valve job. I usually do a valve job with just lapping the valves so the cost is mostly just a few gaskets. Good Luck, Rick
It would help to know what engine we are talking about. Pictures as we go will help too.
Do check the flywheel key too.
Edited by boyscout862, March 07, 2013 - 09:08 AM.
#18 Kentrails OFFLINE
Kentrails
  • 13 Thanks
  • 52 posts
Posted March 07, 2013 - 03:58 PM
There is a Briggs and Stratton manual available on line for engine...
Model~326437
Type ~  0328-01
Code ~7911271
#19 Kentrails OFFLINE
Kentrails
  • 13 Thanks
  • 52 posts
Posted May 03, 2013 - 11:30 PM
Well, here's what I have after removing the carb. This is the 16 hp B&S-1979 model. sorry about the amount of time between posts , my duties have been overwhelming me, 12 acres of weeds, yes acres,  mostely my back.
#20 Kentrails OFFLINE
Kentrails
  • 13 Thanks
  • 52 posts
Posted May 12, 2013 - 11:22 AM
Well I engineered a rope with a knot and juniper handle, approx 2 cubits long and I pull start it, skrew the stsrter.
