Brake Band Needed For Jake Chief 1000
7 replies to this topic
#1 Randy56 OFFLINE
Randy56
  • 1 Thanks
  • 6 posts
Posted February 13, 2013 - 11:05 AM
I am having trouble finding a brake band for my chief 1000. It has a 4" drum and a model no. 53038. Can anyone help me or at least point me in the right direction? Will eventually need some other parts but right now I have no brakes. Thx for all your help. Randy
#2 KennyP ONLINE
  • 40,044 Thanks
  • 46,732 posts
Posted February 13, 2013 - 11:45 AM
I know I have seen threads on getting the new band material and bonding back to your metal, just not sure where at the moment.
Found this:
http://www.northernt...uct_21294_21294
Edited by KennyP, February 13, 2013 - 11:57 AM.
Added comment
  • boyscout862 and tgreeson have said thanks
#3 boyscout862 OFFLINE
  • 13,431 Thanks
  • 9,380 posts
Posted February 13, 2013 - 12:11 PM
Nice work Kenny. I was thinking the same thing. Many of the parts for old GTs are generic. I also check the surplus sites.
Edited by boyscout862, February 13, 2013 - 12:11 PM.
#4 KC9KAS OFFLINE
KC9KAS
  • 5,443 Thanks
  • 4,710 posts
Posted February 13, 2013 - 06:05 PM
Oops...didn't copy & paste quite right....Here is the website..http://www.mcmaster....-lining/=lgrwz3
From McMaster Carr................ Brake and Clutch Lining
3976kp1s.png?ver=17742567
Low Friction
6090kp1s.png?ver=17742511
Medium Friction
60895kp1s.png?ver=17741931
High Friction
6175k552p1s.png?ver=17742502
Metal-Free
6224k741p1s.png?ver=17742484
High Strength
Also known as friction materials, these sheets and strips can be riveted or bonded.
  Max. Rubbing Speed Max. Operating
Temperature Max. Operating
Pressure Max. Coefficient
of Friction Low-Friction Sheets 4,500 ft./min. @ 600 psi 600° F 600 psi 0.14 Medium-Friction Sheets 5,000 ft./min. @ 500 psi 550° F 500 psi 0.35 High-Friction Sheets 5,000 ft./min. @ 500 psi 550° F 500 psi 0.55 Metal-Free Strips 4,000 ft./min. @ 250 psi 500° F 250 psi 0.47 High-Strength Strips 5,000 ft./min. @ 200 psi 500° F 200 psi 0.51
Molded Sheets
Low Friction
Medium Friction
High Friction
Use low-friction sheets for a smooth stop. High-friction sheets provide immediate engagement.
7 1/2" × 7 1/2"
15" × 15"
30" × 30"
Thick.   Each   Each   Each
Low Friction
1/8" 3976K31 $24.86 3976K11 $52.70 3976K21 $175.07 3/16" 3976K32 20.73 3976K12 43.94 3976K22 145.98 1/4" 3976K33 27.50 3976K13 58.29 3976K23 193.67 5/16" 3976K34 28.73 3976K14 60.90 3976K24 202.31 3/8" 3976K35 30.61 3976K15 64.88 3976K25 215.55 1/2" 3976K36 33.49 3976K16 70.98 3976K26 235.83 5/8" 3976K37 43.06 3976K17 91.28 3976K27 303.24 3/4" 3976K38 45.33 3976K18 96.08 3976K28 319.19
Medium Friction
1/8" 6090K21 22.89 6090K11 48.53 6090K36 161.22 3/16" 6090K22 23.29 6090K12 49.36 6090K37 164.00 1/4" 6090K23 24.97 6090K13 52.93 6090K38 175.84 5/16" 6090K24 25.72 6090K14 54.53 6090K39 181.15 3/8" 6090K25 27.68 6090K15 58.67 6090K41 194.93 1/2" 6090K26 30.88 6090K16 65.47 6090K43 217.50 5/8" 6090K27 36.16 6090K17 76.64 6090K44 254.62 3/4" 6090K28 39.00 6090K18 82.68 6090K45 274.68 1" 6090K29 59.07 6090K19 125.22 6090K87 416.00
High Friction
1/8" 60895K11 29.20 60895K21 61.90 60895K71 205.65 3/16" 60895K12 30.92 60895K22 65.55 60895K72 217.76 1/4" 60895K13 32.29 60895K23 68.45 60895K73 227.42 5/16" 60895K14 33.91 60895K24 71.88 60895K74 238.80 3/8" 60895K15 35.94 60895K25 76.19 60895K75 253.11 1/2" 60895K16 42.15 60895K26 89.35 60895K76 296.85 5/8" 60895K17 48.85 60895K27 103.54 60895K77 343.98 3/4" 60895K18 51.24 60895K28 108.62 60895K78 360.87
Strips
Metal-Free
High Strength
Metal-free strips are also known as nonmetallic molded strips.High-strength strips, also known as semimetallic woven strips, have a brass wire woven into the material to increase strength and improve heat dissipation.
To Order: Please specify length: 1, 2, 3, 4, 5, 6, 10, or 15 ft. High-strength strips are also available in 20 and 25-ft. lengths.
Metal-Free
High Strength
Thick. Wd.   Per Ft.   Per Ft. 3/16" 1" 6175K811 $3.20 6224K341 $3.90 3/16" 1 1/4" 6175K812 3.91 6224K342 4.19 3/16" 1 1/2" 6175K813 4.70 6224K343 5.39 3/16" 1 3/4" 6175K814 5.37 6224K344 5.68 3/16" 2" 6175K815 5.21 6224K345 6.51 3/16" 2 1/4" 6175K816 6.20 ______ __ 3/16" 2 1/2" 6175K817 6.20 6224K346 7.64 3/16" 2 3/4" 6175K818 7.37 ______ __ 3/16" 3" 6175K819 7.89 6224K347 9.36 3/16" 4" 6175K821 10.14 ______ __ 3/16" 5" 6175K822 12.46 ______ __ 3/16" 6" 6175K823 14.71 ______ __ 1/4" 1" 6175K824 3.97 6224K348 4.06 1/4" 1 1/4" 6175K825 4.66 6224K349 5.09 1/4" 1 1/2" 6175K826 5.37 6224K351 6.18 1/4" 1 3/4" 6175K827 6.17 6224K352 6.80 1/4" 2" 6175K828 6.89 6224K353 7.66 1/4" 2 1/4" 6175K829 7.54 6224K354 8.66 1/4" 2 1/2" 6175K831 8.29 6224K355 9.88 1/4" 2 3/4" ______ __ 6224K356 10.32 1/4" 3" 6175K832 9.74 6224K357 11.08 1/4" 3 1/2" 6175K833 11.17 6224K358 12.76 1/4" 4" 6175K834 12.57 6224K359 14.87 1/4" 5" 6175K835 15.54 6224K361 18.52 1/4" 6" 6175K836 18.37 ______ __ 5/16" 2" 6175K837 8.86 6224K362 9.36 5/16" 2 1/2" 6175K838 10.57 ______ __ 5/16" 3" 6175K839 12.29 6224K363 13.34 5/16" 4" 6175K841 15.80 ______ __ 3/8" 2" 6175K842 9.70 6224K364 11.22 3/8" 2 1/2" 6175K843 11.68 ______ __ 3/8" 3" 6175K844 13.61 6224K365 16.29 3/8" 3 1/2" 6175K845 15.53 6224K366 19.01 3/8" 4" 6175K846 17.42 6224K367 20.57 3/8" 4 1/2" 6175K847 19.39 ______ __ 3/8" 5" 6175K848 21.34 ______ __ 3/8" 5 1/2" ______ __ 6224K368 29.37 3/8" 6" 6175K849 24.67 ______ __ 3/8" 7" 6175K851 29.00 ______ __ 3/8" 8" 6175K852 32.89 ______ __ 1/2" 2 1/2" ______ __ 6224K369 19.76 1/2" 3" ______ __ 6224K371 23.74 1/2" 4" ______ __ 6224K372 28.16 1/2" 5" ______ __ 6224K373 34.94 1/2" 6" ______ __ 6224K374 40.25 1/2" 8" ______ __ 6224K375 55.95
By using this web site, you agree to our Terms and Conditions
Home|Help|Returns|Careers|Settings
The quick brown fox jumped over the lazy dog. Pedestal (35" Ht. x 4" Wd. x 4" Dp.)
Molded Sheets
Low Friction
Medium Friction
High Friction
7 1/2" × 7 1/2"
15" × 15"
30" × 30"
Low Friction
Medium Friction
High Friction
Strips
Metal-Free
High Strength
Metal-Free
High Strength
Thick.Wd. Per Ft. Per Ft.
Edited by KC9KAS, February 13, 2013 - 06:06 PM.
  • KennyP and DAVESTOYS have said thanks
#5 Wade M OFFLINE
Wade M
  • 65 Thanks
  • 58 posts
Posted February 13, 2013 - 06:51 PM
Randy,
I made my own from metal strapping material from a shipping crate. I had the loops left so I used some small machine screws to attach.  The lining was from McMaster-carr.  I got the high strength (above).  It came 1" wide and the strapping was 3/4".  The material cut well on the band saw to match width. Then I attached the lining using flat head screws.  The lining material drilled well and I used a counter sink so the heads would not get into the break wheel.  I had to make my own wheel also which is a caster from McMaster i bored and broached.
#6 Randy56 OFFLINE
Randy56
  • 1 Thanks
  • 6 posts
Posted February 13, 2013 - 08:50 PM
I still have a perfectly good band, just no lining. I do not know how thick the pad should be. Am also working on having the lining replaced or maybe locating one. Down the line I would like to find some other parts for this unit. Can anyone tell me how to identify my jake snowblower. It is a 36" but I do not know how to tell if it is a 2 stage or single.
#7 Cat385B ONLINE
    HAZMAT CAT
  • 14,258 Thanks
  • 10,106 posts
Posted February 13, 2013 - 09:33 PM
Single stage blowers have paddles in the center of the auger to throw the snow up.
Two stage blowers have a paddle behind the auger which throws the snow up the chute.
#8 Randy56 OFFLINE
Randy56
  • 1 Thanks
  • 6 posts
Posted February 14, 2013 - 11:23 AM
Thx for the info on blowers. Have to check mine when I get home this weekend.
