682 Hydro Leak
15 replies to this topic
#1 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted February 12, 2013 - 05:07 PM
I noticed some oil where the fender pan meets the tunnel cover. I pulled the tins off and cleaned everything up. When I fired it back up and pulled it inside I noticed a tiny bit of fluid comring from what looks like a seep hole in the top of one of the check valves... Any know know what causes this?
Also, I've searched for a manual on the hydro but haven't had any luck. Can anyone point me in the right direction?
#2 KennyP OFFLINE
  • 37,506 Thanks
  • 45,509 posts
Posted February 12, 2013 - 05:42 PM
I don't know if this will help, but I just uploaded a Service Manual for the 82 Series GT's.
#3 CubHorse80 OFFLINE
CubHorse80
  • 159 Thanks
  • 318 posts
Posted February 12, 2013 - 06:05 PM
your check valves may be bad. If you want the right fix, you will have to get new ones or get them rebuilt, but for a quick fix, fill the holes on top with JB weld. DISCLAIMER- filling those holes will not allow you to push the tractor around. Those check valves are mighty expensive! 120 for one new one! :poke:
#4 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted February 12, 2013 - 10:28 PM
Thanks Kenny. I've got tha manual and it doesn't go into any detail on the hydro pump.
So... it doesn't leak that much... I guess it just keeps getting worse? then what happens?
#5 KennyP OFFLINE
  • 37,506 Thanks
  • 45,509 posts
Posted February 13, 2013 - 04:26 AM
Darn it! Guess I'll have to snoop around some more for the right manual!
  • twostep said thank you
#6 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted February 13, 2013 - 09:46 AM
I found this and it has a little more detail: http://gardentractor...ouble-shooting/
#7 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted February 13, 2013 - 09:49 AM
More info:
http://simpletractor...TOPIC_ID=107219
http://cubfaq.com/relief1.html
Edited by twostep, February 13, 2013 - 10:08 AM.
#8 EricFromPa ONLINE
EricFromPa
  • 3,527 Thanks
  • 3,071 posts
Posted February 14, 2013 - 08:29 AM
I welded the hole shut on my 149.It was leaking very bad and someone tried to take it apart before I got it.Looks like some one tried to take the tip off with a pair of vice grips on mine.
I can still push it around but it is Alot harder.Noticed that the cavitation issue I was having with the new fluid went away to.It must of been pulling air into the pump while it was running and pushing fluid out when it was not running.
This guy on Ebay remachines and rebuilds them for $40 each.He's sold 342 and 100% positive feedback so he must know what he's doing.
http://www.ebay.com/...=item4aa9721237
He also sells rebuildable relief valves for $85 each or $160 for a pair.
http://www.ebay.com/...=item336e4db448
Edited by EricFromPa, February 14, 2013 - 08:38 AM.
  • Alc and twostep have said thanks
#9 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted February 14, 2013 - 12:10 PM
That rebuild seems like a good deal. I don't have enough experience to know if lapping the ball seats is really needed but the new components and bench testing are good selling points.
The rebuildable valves would be great but honestly, I expect my valves are 33 years old... if I can rebuild them and have them last another 30 years I'll be fine with that.
Thanks for the links. Since budget is tight and I can wrecker my 682 with my kubota 3pt I might just weld it up for now. If I don't like it I can grind the spot weld off and rebuild.
Does anyone know why there are two? I assume one is forward and one is reverse. If that is right, any idea which is which?
#10 EricFromPa ONLINE
EricFromPa
  • 3,527 Thanks
  • 3,071 posts
Posted February 14, 2013 - 08:05 PM
Here's a pic out of my dealer manual.It's for an older pump without hydro lift but it's basically the same.
#11 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted February 14, 2013 - 09:44 PM
Thank you. It does seem that after pressure washing when I was putting the tractor back in the garage it seemed sluggish backing in... and according to that pic the Reverse valve is the one that was leaking.
#12 dsmithjr OFFLINE
dsmithjr
  • 49 Thanks
  • 72 posts
Posted February 19, 2013 - 08:06 AM
Just my 2 cents but I would never weld them up they are way to expensive and forcing the tractor to roll with out pressure relief will damage the pump which is really expensive. There are a lot of rear ends around so I'm sure if you post a wanted add someone has a decent one you can buy until you can have yours rebuilt. If you pressure washed your rear end you may have damaged the vent hole at the back of the rear end and now its building pressure and leaking out of the valves( this only applies to the IH cast rear ends) not the CC aluminum rear ends.
#13 croustd OFFLINE
croustd
  • 3 posts
Posted June 07, 2017 - 12:49 PM
I just picked up an old (but goodie) 682.  I notice that the transmission level was low, so I added some oil....And then found out why it was low.  There is a leak somewhere.  Went to the local mower shop (deals with cubs).  He said new cork seal.  No sealant and sticky side on transmission.  So, after pulling it all apart and putting it back together.  Fresh oil. Fresh filter..........drum roll.  It is still leaking from somewhere.  Anybody got any ideas?  Should I have put sealant on the cork seal?  I think it may be the up shafter retainer seal.  After driving around it drip from the bottom of the transmission.  follow it up and and it comes from some where around the cork seal area.   I think the only thing above that would be the shaft retainer seal.  You guys got any suggestions?
#14 olds45512 OFFLINE
olds45512
  • 1,338 Thanks
  • 677 posts
Posted June 07, 2017 - 04:56 PM
Best suggestion is to pull the fenders and give it a good cleaning, once its dry it will be pretty obvious. its likely the relief valves or the trunion seal.
#15 croustd OFFLINE
croustd
  • 3 posts
Posted June 07, 2017 - 08:23 PM
Thanks for the quick reply.  I found out that it is actually the shaft seal on the hydro pump.  My cork gasket is holding fine.  I wiped everything clean, the put a rag under the shaft, ran around for a while and the rag is wet.  Looks like the hydro pump has to come back off and apart for a new seal.  Breaking down the hydro pump might be a bit above my pay grade.  Anyways, thanks for the help!
