The Tubes In Tube Frames..
16 replies to this topic
#1 Texas Deere and Horse OFFLINE
  • 15135 Thanks
  • 15577 posts
Posted February 11, 2013 - 05:22 PM
Do all the tube frame leave the front end of the pipe open? Mine are open under the grill and are out of round some. If they had caps in them like the back end does, they wouldn't mash as much.
Back of Tube frame at trans-axle.
Front of tube hidden by grill and front axle support.
#2 8tyman8 OFFLINE
8tyman8
  • 466 Thanks
  • 757 posts
Posted February 11, 2013 - 06:03 PM
None of the tube frames used Caps on the front .. it would be a Good idea tho .. how ever some used 2 bars (4 in total) in the frame ( 12" 1 3/4" 1/8"?) to keep it from Squashing and trust me they will squash if they are not there
  • Texas Deere and Horse and boyscout862 have said thanks
#3 Ryan313 OFFLINE
  • 3441 Thanks
  • 5250 posts
Posted February 11, 2013 - 08:50 PM
I see a hole in the side on the front end, does it have a nut or bolt there you have to access through the end?
  • Texas Deere and Horse and Trent Thomson have said thanks
#4 Bolens 1000 ONLINE
  • 17552 Thanks
  • 18863 posts
Posted February 11, 2013 - 08:53 PM
The front end of the tubes were open.
Normally the tubes stayed intact but a few times there would be cases where people would be plowing snow and raming the plows into the pile which would loosen the 4 bolts and crush the tubes.
In the early 70's a "Frame reinforcement" Kit was made available to correct the problem.
  • Texas Deere and Horse, sacsr and boyscout862 have said thanks
#5 boyscout862 OFFLINE
  • 15260 Thanks
  • 10022 posts
Posted February 11, 2013 - 09:25 PM
Any idea what it looked like? I have 5 tube frames and atleast 3 have frame problems. At one piont I was thinking about finding pipes and making new frames.
#6 Bolens 1000 ONLINE
  • 17552 Thanks
  • 18863 posts
Posted February 11, 2013 - 09:28 PM
I have the 1 page service Bulletin
If I remember correctly it has a drawing of them.
Will get it uploaded in a day or two....
  • Texas Deere and Horse, Bruce Dorsi and boyscout862 have said thanks
  • 15135 Thanks
  • 15577 posts
Posted February 11, 2013 - 10:26 PM
Ryan, On the Tube Frame tractors, everything bolts thru the tube, this end is crushed from the front axle support being tightened a few times and the pipe ovaling it's shape causing the bolts to come loose and then being re-tightened.
I hope that makes sense to you. I don't always explain things well. :wallbanging:
#8 1978murray OFFLINE
1978murray
    diesel mechanic
  • 610 Thanks
  • 1165 posts
Posted February 12, 2013 - 08:44 AM
would panzers be classified as a tube frame?  lol
#9 Bud W OFFLINE
Bud W
    old member
  • 520 Thanks
  • 407 posts
Posted February 12, 2013 - 03:22 PM
I have 2-1256's that had the same problem. I cut the crushed ends off and replaced them with new tube the same size. I bought tube that fit perfectly inside the frame tubes, and plug welded them in and re-drilled all of the holes. It is much stronger than original and you can't even tell.
#10 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted February 12, 2013 - 03:28 PM
The mice have to live somewhere...
#11 Bolens 1000 ONLINE
  • 17552 Thanks
  • 18863 posts
Posted February 13, 2013 - 11:22 AM
  • Texas Deere and Horse and Bruce Dorsi have said thanks
#12 Texas Deere and Horse OFFLINE
  • 15135 Thanks
  • 15577 posts
Posted February 13, 2013 - 11:58 AM
Thanks Doc., :thumbs:
Is that a pipe bushing for the bolt to slide thru or a piece of something else?
#13 junkpile OFFLINE
junkpile
  • 7 Thanks
  • 22 posts
Posted February 13, 2013 - 01:30 PM
I just looked at a 1050 which the owner dismantled the whole machine and filled the tubes with lead and plugged both ends with steel plugs he machined to prevent the bolts from crushing the tubes.
I thought it was overkill until I read this post. I've not yet owned a tube frame myself.
I can't imagine the process it took to fill the frame with lead, but he uses the thing to plow a garden and push snow, so the added weight would be more than welcome.
#14 Bolens 1000 ONLINE
  • 17552 Thanks
  • 18863 posts
Posted February 14, 2013 - 06:42 AM
Looks like its just 2 bushings that help strengthen the tubes from crushing. I'm not sure though as I never seen a kit on one in person...
#15 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5121 Thanks
  • 2911 posts
Posted February 14, 2013 - 10:05 AM
I'm not sure, because I never saw one of these kits either, but according to the text in the service bulletin, I'm thinking it is 4 pieces of flat-stock set in place to straddle the bolts  ....The width of the flat-stock will keep them from "tilting" and tightening the bolts should keep the reinforcements from sliding rearward.
The text says: "...insert two (2) into each frame tubing ...with front end flush with end of tubing."
I can't see the bottom illustration on the service bulletin clearly.  .....Any help, Brian?
