V36 Throttle Linkage Help
4 replies to this topic
#1 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,792 Thanks
  • 2,307 posts
Posted February 11, 2013 - 04:06 PM
Hi guys,
     I was able to get her to start, but she never came with the throttle hooked up correctly. Engine is a Tecumseh HH60 here's the photos:
Anyone have the proper linkage diagram for me? Thanks a ton!
#2 superaben OFFLINE
superaben
    Con Man
  • 7,665 Thanks
  • 5,677 posts
Posted February 11, 2013 - 04:20 PM
Try chapter 4 in this manual:
http://gardentractor...-manual-692509/
If that doesn't help, I might have an H60 in the pile that I can snap some photos of.  I've also got the governor linkages/springs as an assembly if you are missing pieces.
Ben W.
#3 olcowhand ONLINE
  • 38,028 Thanks
  • 30,448 posts
Posted February 11, 2013 - 04:21 PM
Here ya go.  Your cable connects to the little vertical arm that connects via spring to the carb throttle plate.
You adjust the governor via the small screw on the governor arm that the rod is attached to.  These are difficult to get right.
  • CRFarnsworth said thank you
#4 olcowhand ONLINE
  • 38,028 Thanks
  • 30,448 posts
Posted February 11, 2013 - 04:24 PM
I use springs from an assortment pack, but you have to be used to this kind of thing to get the right spring.  Best to get a spring from Ben (superaben) so you'll know you have the correct one.  He may also have the control rod.
#5 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,792 Thanks
  • 2,307 posts
Posted February 11, 2013 - 04:30 PM
Thank you both, it looks like I am missing that spring and connection rod. I'll be contacting Ben. Thank you Daniel!
