My Lt1000 Throwing Nemo Snow
20 replies to this topic
#1 Oo-v-oO OFFLINE
Oo-v-oO
  • 341 Thanks
  • 448 posts
Posted February 10, 2013 - 09:40 PM
We didn't get nearly as much snow as you guys down South of us did. I measured only around 14" after it stopped snowing, but it seems like other areas around town got more so who knows, with all the blowing and drifting. It was a pretty fine, dry snow.
I did most of my clearing on Saturday but had a little more left to clean up that I took care of today and I shot some video of it.This was my first real test of any amount of snow with the LT1000 that I repowered with a 19.5hp Briggs opposed twin. I am very pleased with the outcome. The limiting factor is definitely how much snow you can put through the blower and power is not even close to being an issue.  :thumbs:
I'm sold on two-stage blowers. Not sure how far I'm chucking the snow, but It has to be at least 40' if not more. if the snow had just a bit more moisture I think I could have thrown it further and in a more cohesive stream.
Enjoy!
  • MH81, jms180, KennyP and 6 others have said thanks
#2 Cat385B OFFLINE
    HAZMAT CAT
  • 13,973 Thanks
  • 10,002 posts
Posted February 10, 2013 - 09:48 PM
Very impressive distance with that set up there. That would kick the carp out of any single stage I've ever used.
  • Oo-v-oO said thank you
#3 HowardsMF155 OFFLINE
  • 2,861 Thanks
  • 2,987 posts
Posted February 10, 2013 - 10:14 PM
Two stage blowers rule when you are looking to throw the snow far enough away it won't bother you again.  Yours looks like it ranks right up there with a Gravely!!
#4 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1,088 Thanks
  • 1,284 posts
I could sit here and watch that all day. Wicked cool. It reminds me of the tail shooting out the back of those speed boats. Thanks for the video. Your video makes me want to write a letter....
"Dear Santa,
I want a two stage snow blower that will fit my 1971 Case 444 for Christmas.
Matthew"
My single stage gets the job done but NOT in that kind of style.
#5 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,982 Thanks
  • 4,410 posts
Posted February 10, 2013 - 10:20 PM
Awsome, Very good angle.... Ive watched too many snow blowers this weekend, and I have to say your vid is the most impressive. From someone that hasn't blown snow before, and pushed mud this weekend in shorts.
#6 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Wow, that really does throw the snow!! Great machine!! :rocker2:   Thanks for sharing!
Geno
#7 MH81 OFFLINE
Posted February 11, 2013 - 12:16 AM
Very neat demo of what it can do. Thanks for taking the time to upload it. After seeing that, I may have to rethink my want for a two stage... I'm coming close enough to my neighbors house with my single stage... With that, I would probably end up filling their living room.
#8 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted February 11, 2013 - 04:46 AM
Wow! That throws it a ways! Cool video!
#9 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted February 11, 2013 - 05:09 AM
Nice video....That GT really "Got-R-Done"!
#10 Oo-v-oO OFFLINE
Oo-v-oO
  • 341 Thanks
  • 448 posts
Posted February 11, 2013 - 05:42 AM
If you don't want as much range it is as easy as pulling back on the throttle, or angling the chute deflector down a little bit. I was blowing at full throttle, which is what you usually want to do.
2-stage blowers work better with less than a full bucket of snow than single stages do, and they also tend to plug up the chute less.
Edited by Oo-v-oO, February 11, 2013 - 05:42 AM.
#11 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted February 11, 2013 - 06:04 AM
That's doing a great job. The snow we got was perfect for blowing. My Ariens walk behind was throwing it a good distance as well.
#12 skyrydr2 OFFLINE
  • 3,886 Thanks
  • 3,410 posts
Posted February 11, 2013 - 06:44 AM
Yup that sure does a sweet job, in fact it looks to be the same blow as mine ? They can really eat the snow !! And that was a nice angle on the video! I can only get video from the operator's platform. Wife is terrible with a camera.
#13 Oo-v-oO OFFLINE
Oo-v-oO
  • 341 Thanks
  • 448 posts
Posted February 11, 2013 - 05:59 PM
For the first clip I set it on my utility trailer and the second on a blue plastic drum. My wife would have probably recoded for me if I asked but I figured this was more steady and the drum wasn't going to roll its eyes at me.  :D
I don't have the model number handy but it is a 40" Agri-Fab. It's branded Craftsman, in any case, but is probably the same as for several other brands except for paint and decals.
#14 skyrydr2 OFFLINE
  • 3,886 Thanks
  • 3,410 posts
Posted February 11, 2013 - 06:32 PM
That's what mine is too , but mine is 46" wide . It works AWSOME ! And is quite well built . Does yours have the step up gear box that drives the blower and augers ? Mine has this and I had to flip it so it actually turned the blower/auger shaft slower . I was able to run mine direct drive with a driveshaft instead of all the pulleys and belts.
#15 Oo-v-oO OFFLINE
Oo-v-oO
  • 341 Thanks
  • 448 posts
Posted February 11, 2013 - 07:29 PM
No, mine has a mule drive assembly under the middle of the tractor which drives down to a long belt that extends forward under the front axle. The belt goes over a pair of idler pulleys that put a 90° twist in the belt so it will go around the driven pulley which is mounted on a horizontal shaft that the second stage impeller is mounted on.
Mine has a 3-bladed impeller; I think yours is probably the 4-blade verson which is also larger diameter than mine. They throw a greater volume of snow even further than mine, I think.
