Wh B-80 Won't Roll Forward?
17 replies to this topic
#16 junkpile OFFLINE
junkpile
  • 7 Thanks
  • 21 posts
Posted February 13, 2013 - 01:58 AM
The 8hp from the Cub looks normal, it bolts down to a flat plate between the frame rails. The pan has mounting ears but the motor bolts up from below using another set of holes.
The bolt pattern looks the same on the WH B-80.
So what should I offer for the machine minus the motor now? I'm thinking $150 tops but I'm sure he can get more than double that on eBay.
#17 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted February 13, 2013 - 08:11 AM
The cub 8hp will bolt in direct if you have or make the riser plate that would have been in it before the engine swap.  Problem is cub used a shorter crank shaft  on most of there engines tan WH did. Measure length first.
 And me I'd offer $100 for it as a roller Putting stuff on ebay ain't as cheap as people think Tell him to check what it will cost him, listing fee's, auction fee's, paypal fee,s People forget it's not a free auction site.
#18 yardiron OFFLINE
yardiron
  • 23 Thanks
  • 78 posts
Posted February 14, 2013 - 02:18 AM
You will also need the clutch for the 8hp, the 14hp most likely had a larger crank diameter, if the engine buyer didn't get the clutch and pulleys.
eBay takes a big chunk, as much as 40% on some items, but the bottom line is that its still the best place to get national attention and to sell many items that would never sell locally. Myself, I'd never list a whole tractor, I'd part it out down to the tiniest nut or bolt. Relist nothing unless its free, and lump all the unsold small parts in the end for a final listing as a lot, all else gets scrapped.
I'd figure that the trans would be worth $50-100, the deck maybe $200-300, the mule drive another $40, the rear wheels, maybe another $75, the front wheels another $50, the hood maybe $75, the fenders, $25-50 if shipping don't kill their sellability, and the rest is potluck as to whether you find someone that needs them that week. Even still, subtract 40% from the list of items sold on eBay and its far more than $100. If the seller of that tractor does do eBay, he's fully aware of this. I've bought various machines for cheap locally and cleared well over a grand per machine on eBay, it depends on the machine, the time of year, condition, and often how much it'll cost to ship. Most buyers include shipping in their total cost when bidding, so the more it costs to ship, the less you make whether or not you do free shipping.
If that were mine, I'd not let it go for less than $250 minus the motor, with or without the clutch, if it had its orignal clutch for the proper motor, I'd add another $40 or so, or what ever a good used clutch would run. I sold the deck from my last WH locally for $300, I kept the motor, sold the tractor hulk for $350, and sold the original chrome hubcaps for a $100. I very well could have parted it out further but needed the room and the WH was the least valuable of the lot of tractors I had just bought.
If I were you, I'd look at putting a larger motor back in it, it'll bolt into the frame and if you do have the clutch from the 14hp, it'll save you another expense.
