Amf...what Is It?
20 replies to this topic
#16 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted February 09, 2013 - 07:45 PM
Will, If it is the peerless transmission, it is 4 speed plus reverse, all modified by the five settings on the varidrive.
Yes, I gapped there. The 2 and 1 gear are on the same stroke. Back and to the right.
#17 JDBrian OFFLINE
  • 9679 Thanks
  • 14162 posts
Posted February 09, 2013 - 09:36 PM
The mf8 is a 3 speed Will. Maybe that's where the 3 came from. Nice system. The vari speed seems to be a source of problems when it's worn or not maintained properly. I'd like to get a MF or JD with that system on it. Seems to me it would be good for blowing snow.
#18 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted February 10, 2013 - 04:13 PM
I posted the listing in the CL/eBay forum.
http://cleveland.cra...3605240358.html
#19 MF10 DIESEL OFFLINE
MF10 DIESEL
  • 76 Thanks
  • 202 posts
Posted February 24, 2013 - 02:07 PM
Think of it as a 4 speed manual with a clutchless semi automatic transmission in front of it. The 5 speeds on the the side of the dash tower are shift on the fly, the 4 on the floor require a clutch to shift.. unless you can float it.
#20 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted February 24, 2013 - 02:59 PM
The vari-drive is a great system as long as it is working and adjusted. I have it on my Deere's. It enables you to adjust speed without losing implement speed or pushing in the clutch. Great for mowing. Once I got used to it I find I use it all the time. In the stock pulling classes they call it a cheater stick. It enables you to get a few more feet after your engine starts to bog. Its tricky and takes a few tries to adjust it right but doesn't lose adjustment till the belts start to wear. Its solely dependent on good belts. Eric Sent from my SPH-D700 using Tapatalk 2
#21 bread320i OFFLINE
bread320i
  • 614 Thanks
  • 1225 posts
Posted February 24, 2013 - 03:11 PM
I like the vari-drive on my Massey Ferguson MF12.It certently does not replace the hydro, but does many things a regular gear drive tractor cant.
