Eaton 10 Hydro's !
10 replies to this topic
#1 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted February 09, 2013 - 03:55 AM
.. I have asked before even asked Duff So here we go Straight up Does any one have ANY information on eaton 10 Hydros Besides whats one the on Eaton site and under the bolens manuals The most Imprtant thing is The date code number-letter System ..
Thanks for any thing
Tyler
#2 KennyP OFFLINE
  • 35,059 Thanks
  • 44,081 posts
Posted February 09, 2013 - 05:35 AM
Not sure what you are looking for here. I have a sample from an Eaton 11.
Are you looking for what the Letters translate to?
#3 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted February 09, 2013 - 03:27 PM
Yes some what ... how ever i think the 10 series number system is Different as i crawled under my h14 and the numbers start with 15 and i will tell you its not a model 15 as i don't think that was ever made ... and how does that number system work .. Date code a10a ? What the heck does the A for year translate to .....
#4 KennyP OFFLINE
  • 35,059 Thanks
  • 44,081 posts
Posted February 09, 2013 - 03:35 PM
That's why I was asking. I haven't found anything on the Eaton 10. I haven't a clue how they read that code. Guess it's time to go to their page and ask them.
#5 KennyP OFFLINE
  • 35,059 Thanks
  • 44,081 posts
Posted February 09, 2013 - 03:47 PM
I did find this service bulletin.
#6 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted February 11, 2013 - 05:01 PM
So here we have some more numbers
The first one is a (i think Eaton 11 out of my 1256 when i pulled the hydro the 12 point bolts were slightly Rounded and when i took the drive shaft out there was a second set screw mark .. leading me to believe that its been out before Also the case drain is a #10 orb fitting thats been reduced with some fittings )
The second one is a ? 10 ???? !! but it does not start with 10 like i expected it starts with 15.. my other eaton 10 in my h14xl says 10 at the beginning
15160 1
Cw C25E
S
And Last But Not least a Known eaton 11 from a 1700 eliminator
1100 -019
C18A ccw
Honestly im stumped on this one
Edited by 8tyman8, February 11, 2013 - 05:06 PM.
#7 skyrydr2 ONLINE
  • 3,837 Thanks
  • 3,380 posts
Posted February 11, 2013 - 06:46 PM
 What are you trying to do ? All those  look like an Eaton 11 . they have almost 100 different versions of it . This is why they are numbered . If you read the pdf's from Eaton on these they have a code sequence . There are sooo many different versions it boggles the mind .
#8 wilberj OFFLINE
wilberj
  • 4,837 Thanks
  • 5,510 posts
Posted February 11, 2013 - 07:19 PM
The 1256 have a eaton 10 well the H14xl has the eaton 11.
#9 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted February 11, 2013 - 09:41 PM
When i got my 1256 and H14 i planed to Upgrade the hydro's to Eaton 11's i think your Diesel ford is a 11 .. ? right the eaton 10 and 11's are Nearly Identical How ever i think the Beefed up internal parts to take higher power Also they run cooler and more efficient And they drive Way smother then the 10 but any Eaton 11 i have had are CCW rotating All the tube frames run Cw What I Am looking for is the Year decoder for the Model 10 Trans the decoder for the 11 is different ..
#10 skyrydr2 ONLINE
  • 3,837 Thanks
  • 3,380 posts
Posted February 12, 2013 - 08:03 PM
 I believe the only difference is that the 10's dod not have any cushion valving  on the stator like the newer 11's . Other than that I think they can be swapped around . You can reverse the rotation on the 11's if you follow the procedure to the letter in the service manual from Eaton . Only thing you might need to do is use your charge pump from the cw 10 ? Not positive on this though , you need to do more homework . Read the Eaton repair manual and know it like your hand ! Then go for it !
#11 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted February 12, 2013 - 08:30 PM
I plan to do that to my h14 come summer time (when i have my Diesel done and at home) as it uses the rear end as the resivor for the fluid unlike the 1256 what has a external tank and a case drain-vent thing on the top but i still think that my 1256 has a eaton 11 as it sounds Alot quieter and smother then the 10 in my h14 so i am thinking that its just the charge pump and i have driven a 11 Backwards (cw) instead of ccw it did drive but once is ran out of fluid from the charge pump it stopped ran it ccw for a bit (in neutral )till it filled back up and works again is cw till it runs out of fluid Are you talking about Pg 16-17-18? in the manual All it mentions is Port plate .. and the different Charge pumps used .. SO i think (come summer that i might swap the charge pump off my 10 put it on the 11 and slap some new seals in the son of a gun then back in the tractor .. or i might just leave it Ahh we will see in the summer ... i just wish there was more literature....
