Monster Air Compressor For Media-blasting
21 replies to this topic
#1 markdombroski OFFLINE
markdombroski
  • 196 Thanks
  • 432 posts
Posted February 08, 2013 - 05:58 PM
I just acquired a new (new to me) air compressor to power my sand-blasting cabinet (and more).  I found this compressor on Craigslist for a great price.  It is a 10HP 2stage-2cylinder 120Gallon unit and will deliver 30+ SCFM capacity.  This is a single phase 10HP motor.  I will need to get a Magnetic Start switch, replace the pressure switch, and replace the belts to get this one running.
I currently have a 5HP, 80 Gallon, 17 SCFM unit, but would like more capacity for those tough blasting jobs.
Edited by markdombroski, February 08, 2013 - 06:00 PM.
  • Toolpartzman and larryd have said thanks
#2 KennyP ONLINE
  • 31,368 Thanks
  • 41,580 posts
Posted February 08, 2013 - 06:18 PM
That ought to do it!
  • markdombroski said thank you
#3 Ryan313 OFFLINE
  • 3,240 Thanks
  • 5,159 posts
Posted February 08, 2013 - 06:19 PM
That should keep up with your blaster! Congrats!
#4 markdombroski OFFLINE
markdombroski
  • 196 Thanks
  • 432 posts
Posted February 08, 2013 - 06:25 PM
Thank you!  yes, my current compressor runs a 70% duty cycle when media blasting.  I am working the pump really hard and it doesn't have very much time to rest and cool down.  This new compressor will be able to keep up the the air demand.  Of course, I may get a higher capacity gun/tip and run it hard as well.
Edited by markdombroski, February 08, 2013 - 06:42 PM.
#5 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted February 08, 2013 - 06:59 PM
  Great score Mark. I didn't know you could buy 10HP in single PH. Learn something everyday.
#6 markdombroski OFFLINE
markdombroski
  • 196 Thanks
  • 432 posts
Posted February 08, 2013 - 07:15 PM
Thank you!
The 10HP Single Phase units are not common.  Most of the 10HP units are 3-phase.  Commonly these compressors are used in Commercial applications such as shops and businesses where 3-phase is readily available.  The most important thing for the single-phase motor is to have an appropriately sized circuit breaker, wire gauge, Magnetic Starter switch, and thermal overload protection.  I will have to run 3 conductors (Red/Black/Green) of 6 gauge wire in metal conduit to the compressor. For air distribution, I will install black-iron 1" pipe back into my work shop.  It will probably cost about $500 in the wire, pipe, and start switch just to get the system installed properly.  I think that 10HP is probably the largest system you can run on Single phase 220.
Unfortunately, it has been common practice for air-compressor manufacturers to over-inflate their capacity numbers and misrepresent their product so they can have a competitive advantage.  Sometimes a motor marked at 10HP is really 7.5HP...etc.  You can look at the motor tag and do some calculations to determine if the motor is really rated as advertised.  The Marathon motor on my new compressor is truly 10HP at the output shaft.  This is done by calculating the Watts (Volts x Amperes).  Then Convert to Horse Power (Watts / 746).  Then multiply the Horse Power by an efficiency factor (HP x FLEF).  This gives you the true output shaft HP.
Edited by markdombroski, February 08, 2013 - 07:22 PM.
  • caseguy and larryd have said thanks
#7 Arti OFFLINE
Arti
  • 1,334 Thanks
  • 979 posts
Posted February 08, 2013 - 07:21 PM
Nice find on a super air compressor.
Actually my catalog lists a Baldor 15 hp single phase motor !!
#8 markdombroski OFFLINE
markdombroski
  • 196 Thanks
  • 432 posts
Posted February 08, 2013 - 07:23 PM
Wow!  I learn something new!  That is one big-@$$  motor.
#9 HDWildBill OFFLINE
  • 8,918 Thanks
  • 8,646 posts
Posted February 08, 2013 - 07:24 PM
Wow what a compressor!  that should to the job very nicely.  Enjoy.
#10 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,033 Thanks
  • 1,457 posts
Posted February 08, 2013 - 07:50 PM
Nice!!! You should have plenty of capacity to run your sandblaster with that.
Edited by LTD, February 08, 2013 - 07:50 PM.
#11 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted February 08, 2013 - 08:13 PM
Good find. That compresssor should allow you to shut the other one down and use for a backup .
larryd
#12 UncleWillie OFFLINE
  • 13,545 Thanks
  • 7,975 posts
Posted February 08, 2013 - 08:17 PM
Nice find. You will be blowing hard in no time.
#13 JDBrian OFFLINE
  • 9,593 Thanks
Posted February 08, 2013 - 10:24 PM
Nice compressor. I'm guessing that will need a 50amp or higher breaker?
#14 NUTNDUN OFFLINE
  • 10,282 Thanks
Posted February 08, 2013 - 10:49 PM
Great find. I know finding single phase motors larger than 7 hp isn't the easiest thing to do and once they get over 7 hp the price ratio to hp goes up. I have a thread buried in the shop forum somewhere with the old Ingersoll Rand we picked up and put a new motor and all the wiring in for it.
Still gotta get a sandblast cabinet to go with it though. :D
#15 dodge trucker ONLINE
dodge trucker
  • 1,559 Thanks
  • 2,039 posts
Posted February 08, 2013 - 11:03 PM
and I thought my compressor was overkill; I have an Emglo 5HP/80 gallon w5-80V  4 cylinder 2 stage pump, I dont remember the CFM I think it's like 21 CFM at 175PSI.  but what ever it is I have done lotsa sandblasting (100 lb pressure pot)  with it and have yet to "out work" it or have to wait for it to catch up; sometimes I get a lil anxious to get started while I wait for that initial charge after I have drained the tank.... I think that has slowed a bit, it's due for a rebuild this will be its 1st since it was new in 1987, I have a kit on order  I have way more than gotten my $500 worth of use from it in the 10 or 12 years I have owned it so far....
Edited by dodge trucker, February 08, 2013 - 11:03 PM.
