Rear Riding Mower Question R70 V.s. S82
5 replies to this topic
#1 markdombroski OFFLINE
markdombroski
  • 196 Thanks
  • 432 posts
Posted February 08, 2013 - 05:17 PM
Hello All,
Does anyone know if a front Axle from a R70 (R72/R92) Riding mower will fit into a S82 model?
Regards,
- Mark
#2 Trav1s ONLINE
Trav1s
  • 3,574 Thanks
  • 4,547 posts
Posted February 08, 2013 - 05:37 PM
JD parts shows:
R72 front axle is part # AM34486
S82 front axle is part # AM37389
Two different part numbers lead me to believe they will not directly swap.
  • markdombroski said thank you
#3 markdombroski OFFLINE
markdombroski
  • 196 Thanks
  • 432 posts
Posted February 08, 2013 - 05:39 PM
Hi Travis,  Yes I also just found the parts as well on the John Deere parts lookup.  They appear to be very similar and may actually fit, but definitely are different.
Thank you again.
- M
#4 markdombroski OFFLINE
markdombroski
  • 196 Thanks
  • 432 posts
Posted February 08, 2013 - 05:41 PM
Here is a PDF that I put together comparing the two models.
#5 Trav1s ONLINE
Trav1s
  • 3,574 Thanks
  • 4,547 posts
Posted February 08, 2013 - 06:08 PM
Ok, did not know if you have used JDParts...
That being said, I would consider swapping the entire sub-assembly if I tried it.
Edited by Trav1s, February 08, 2013 - 06:09 PM.
#6 markdombroski OFFLINE
markdombroski
  • 196 Thanks
  • 432 posts
Posted February 08, 2013 - 06:12 PM
Hi Travis,  I have some R70 parts that I am parting out.  In particular a Front Axle with Tie rod ends, Steering wheel, and front wheels on rims.
