Kohler K482 30 Amp Charging System Replacement
kohler charging stator
3 replies to this topic
#1 Bud W ONLINE
Bud W
  • 315 Thanks
  • 297 posts
Posted February 08, 2013 - 03:54 PM
Hi,
I have a Kohler K482 (Bolens 1886) that needs the stator and rectifier/regulator replaced. Does anyone know if I can change out the 30 amp stator and rect/regulator with a 15 or 25 amp stator and rect/regulator that will fit the original flywheel?
#2 bhts ONLINE
bhts
  • 1,465 Thanks
  • 2,162 posts
Posted February 08, 2013 - 03:58 PM
No you will also have to change the flywheel.
  • Bud W said thank you
#3 Bud W ONLINE
Bud W
  • 315 Thanks
  • 297 posts
Posted February 08, 2013 - 04:01 PM
Hi Bob,
Thanks for your reply. Can you tell me what the difference is with the flywheel (so I'll know what to look for)?
#4 bhts ONLINE
bhts
  • 1,465 Thanks
  • 2,162 posts
Posted February 08, 2013 - 04:30 PM
The flywheel on a 30 amp system has the magnets in a ring and the 15 amp will be glued to the flyheel. here is a pic of the 30 amp flywheel and a link to a 15 amp one we have for sale. The 20hp will fit the 18hp.Also the 30amp ring will be smaller dia as the 15 one.
http://www.ebay.com/...=item35b9e72824
Edited by bhts, February 08, 2013 - 04:31 PM.
Also tagged with one or more of these keywords: kohler, charging, stator
