Spindle interchange on decks
Started by
pajesse
, Sep 21, 2010 07:28 AM
7 replies to this topic
#1
OFFLINE
Posted September 21, 2010 - 07:28 AM
Can I use a blade spindle from a model 19210 deck on a model 50048s deck?
I really just need the spindle shaft replaced, does anyone know if they are the same?
Thanks, Pajesse
Thanks, Pajesse
#2
OFFLINE
Posted September 21, 2010 - 07:38 AM
pajesse :welcometogttalk:glad to have you here.
I am not sure if they are the same or not.Which model of Bolens tractor does that fit ?I'm not into the newer Bolens,but someome may be along who can help you.
Edited by mjodrey, September 21, 2010 - 07:44 AM.
#3
OFFLINE
Posted September 21, 2010 - 07:40 AM
This is on a 5020H
#4
OFFLINE
Posted September 21, 2010 - 08:21 AM
Do you have both decks readily available to you or are you looking to order the parts?
#5
ONLINE
Posted September 21, 2010 - 09:21 AM
Here's the parts list for the 50048s Deck: http://sonnys_bolens...ecks/50048S.pdf
Link to the 19210 Deck :http://sonnys_bolens...decks/19210.pdf (this is the deck for the Q series tractors)
Judging by the illustrations they appear to be slightly different. The shaft size looks to be the same though...
#6
OFFLINE
Posted September 21, 2010 - 10:04 AM
I am looking at an assembly on ebay that looks the same but hard to tell by the pic.
Looked at both parts drawings, numbers don't match but then too I got a new part number for the shaft for 50048s from a dealer. (old #1742606 = new # 1742625)
#7
ONLINE
Posted September 21, 2010 - 10:08 AM
You could always get one from Rays mower shop or sams Bolens. Atleast you would know for sure you got the right assembly. They sell new and used.
Contact info is located in the "Bolens Parts suppliers" thread in this forum.
#8
OFFLINE
Posted September 21, 2010 - 02:01 PM
If you don't have any luck i have new and used ones available.Just pm me.
Both decks used the same style spindle housing assemably only difference was the 19210 usead a 4 bolt shaft and the 50048s usead a 2 bolt.There is also a difference in the spindle shaft lenght.The 19210 was used on the QS/QT tractors.The 1742625 spindle shaft will be about a 1/4 inch shorter then the ones on the 19210 deck.
Edited by bhts, September 22, 2010 - 11:40 AM.
- Bolens 1000 and pajesse have said thanks
