Dang...
10 replies to this topic
#1 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted February 07, 2013 - 05:33 PM
It warmed up to a balmy 43* here today, and in anticipation of Sam's visit to pick up the thatcher, I thought I'd see if I could get the 1886FL running.
The first order of business was to get the Mast forward enough to raise the hood.  I managed to do that so I could check the fuel tank, which was dry as a bone, so I added a gallon or so..  Next I checked the air filter, and was pleasantly surprised to find an almost new one!
Checked the choke and throttle cables and found that they were free and working. Checked the oil, which looks pretty good, and was probably changed not too long before it was parked.
Since the HDT has a 35 AMP alternator in it, I fired it up and used it to jump the 1886FL.
Now for the DANG part.  It cranks over OK, but doesn't seem to be drawing fuel.  I hit it with a quick shot of starting fluid, and it does fire on that, but won't keep running.
Looks like I'll have to go through the fuel system and make sure that it's getting fuel to the carb.  Once I establish that, I guess I'll find out if the carb needs work as well.
  • MH81 and blackjackjakexxix have said thanks
#2 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted February 07, 2013 - 05:45 PM
Hopefully it's just a small issue, nothing major.
#3 JDBrian OFFLINE
  • 9682 Thanks
  • 14162 posts
Posted February 07, 2013 - 05:52 PM
Hope it's not in the carb. I hate tearing into old carbs. But you gotta do what you gotta do to get it working!
#4 HDWildBill OFFLINE
  • 8994 Thanks
  • 8664 posts
I've had that happen and when I opened the float bowl it was a big mess and the jet's were all clogged.  Hope your problem is as big OB.
#5 daytime dave OFFLINE
  • 5494 Thanks
  • 6782 posts
Posted February 07, 2013 - 05:55 PM
Good luck with it.  I hope it is just an easy fix.
#6 superaben OFFLINE
superaben
    Con Man
  • 7672 Thanks
  • 5677 posts
Posted February 07, 2013 - 06:10 PM
I'm jealous as can be.  I have always wanted a forklift Bolens: having a forklift is a good excuse to make a tractor a keeper!  Hope it's an easy one to get running.
Ben W.
#7 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted February 07, 2013 - 07:12 PM
I'm sure the carbon needs to be rebuilt. And I'm sure it has a fuel pump so I would Check that as well
Edited by 1967bolens collector, February 07, 2013 - 07:13 PM.
#8 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3727 Thanks
  • 2367 posts
Posted February 08, 2013 - 10:07 AM
Betting on the fuel pump,probably dried out,I don't think you can get parts anymore to rebuild them,good luck with it
#9 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted February 08, 2013 - 10:22 AM
If that's the problem, this may be the answer.
http://www.kirkengin...ctronicFuelPump
Edited by OldBuzzard, February 08, 2013 - 10:22 AM.
#10 bhts OFFLINE
bhts
    Bob's Lawn and Garden LLC
  • 1493 Thanks
  • 2181 posts
Posted February 08, 2013 - 10:27 AM
I agree with rick as it being the fuel pump. I have the rebuild kits here for the pump if you need it.
#11 UncleWillie OFFLINE
  • 16501 Thanks
  • 9061 posts
Posted February 08, 2013 - 08:38 PM
I hope it is an easy fix. having a forklift and not being able to use it would make me cry.
