Etching Dip Or Paint For E-tanked Parts.
18 replies to this topic
#1 Texas Deere and Horse OFFLINE
  • 14,468 Thanks
  • 15,392 posts
Posted February 06, 2013 - 05:44 PM
I am looking for something to put on my parts right after they come out of the E-tank to protect them til I can get them primed? What do you guys use for this? How do you dry your parts to get them ready for primer?
Thanks in Advance. :thumbs:
#2 IamSherwood OFFLINE
  • 8,382 Thanks
  • 7,696 posts
Posted February 06, 2013 - 06:08 PM
What I do, is take the parts, one at a time, wire brush & water hose (as much as needed),
air gun dry, wipe with final wipe solvent, and get a light coat of self etching primer on.
After they're all safe and sound, I'll put the rest of the primer on.
  • Alc, Texas Deere and Horse, HDWildBill and 1 other said thanks
#3 KennyP ONLINE
  • 30,487 Thanks
  • 41,066 posts
Posted February 06, 2013 - 06:09 PM
When I had mine tank going, it was warm outside. As soon as they dried, I hit them with the Rust Reformer. Then I knew they wouldn't rust again real soon.
#4 JDBrian OFFLINE
  • 9,592 Thanks
Posted February 06, 2013 - 06:20 PM
If the humidity is low I don't worry too much about painting them right away. I usually run over them with a wire wheel anyway before a final rinse with solvent then primer or paint. In places with high humidity I know you have to act quickly to prevent flash rusting.
#5 olcowhand ONLINE
  • 36,494 Thanks
  • 30,067 posts
Posted February 06, 2013 - 06:24 PM
On small parts, once cleaned, I blow with compressed air, then if I'm not ready to primer, I just put them inside my sandblast cabinet.  They almost never rust when I place them in there dry.  If they do rust slightly, I just give them a light blast, take them out, wipe clean, then prime.
  If good & dry weather, after cleaning from the e-tank, I will blow dry, then spray can prime immediately.
#6 Texas Deere and Horse OFFLINE
  • 14,468 Thanks
  • 15,392 posts
Posted February 06, 2013 - 09:30 PM
Thanks guys, I've still got the dash soaking in the tank and I need to get it out and do something with it.
#7 JDBrian OFFLINE
  • 9,592 Thanks
Posted February 07, 2013 - 06:11 AM
Brian I find it works best for me when I take the part out at least once during the process and rinse it, then wire brush any loose paint off it then put it back in in a different orientation. This keeps the big paint flakes out of the tank. It varies a lot from part to part. I've noticed that if something is a bit greasy it slows things down so I try to de grease them before starting. I need to put new anodes in my tank this year. I got 2 years out of the ones that are in there.
  • Alc, Texas Deere and Horse and boyscout862 have said thanks
#8 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted February 07, 2013 - 06:45 AM
Brian you don't have the humidity that we have here and that helps, but once I have the part cleaned and ready for primer, I put it in a closed bag (trash bag etc.) with a generous supply of kitty litter. Its best to prime quickly but not always convenient. This way I don't have to coat for storage, or worry about cleaning again before prime/paint. If a little surface rust shows up, its easy to remove. Just blow off the KL dust and your ready to go.
  • Alc and IamSherwood have said thanks
#9 IamSherwood OFFLINE
  • 8,382 Thanks
  • 7,696 posts
Posted February 07, 2013 - 07:38 AM
Good idea on the kitty litter bag!!
?? what's "KL dust" ?
edit
Now that I've had my coffee, and I'm sitting here looking at my post
I've figured out what KL dust is. Duh...
Edited by IamSherwood, February 07, 2013 - 07:40 AM.
#10 KennyP ONLINE
  • 30,487 Thanks
  • 41,066 posts
Posted February 07, 2013 - 07:42 AM
That's all right, Will. You'll get up to speed after a few more cups!
  • IamSherwood said thank you
#11 IamSherwood OFFLINE
  • 8,382 Thanks
  • 7,696 posts
Posted February 07, 2013 - 07:50 AM
Thanks Kenny.
I'm just about there.
1 more cup
#12 olcowhand ONLINE
  • 36,494 Thanks
  • 30,067 posts
Posted February 07, 2013 - 07:48 PM
I do the same Brian, and the larger or crustier the piece, the more often I do it.
#13 JDBrian OFFLINE
  • 9,592 Thanks
Posted February 07, 2013 - 08:34 PM
Daniel I consider electrolysis tanks to be kind of as magic gift to anyone restoring old iron. It's not fast like a blaster but it sure is easier than a wire wheel and cheap as well. It's kind of rare to find something that saves you work and doesn't cost you a fortune.
#14 KennyP ONLINE
  • 30,487 Thanks
  • 41,066 posts
Posted February 08, 2013 - 08:03 AM
I like using it. I want to run the 'NTM' wheels for the FF thru the tank. Be a lot easier to clean them. That will take cleaning some and rotating them to get all surfaces.
  • Toolpartzman said thank you
#15 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted February 08, 2013 - 06:57 PM
   Don't forget to blow the KL dust off the NTM wheels before you paint.  :rolling:
  • Texas Deere and Horse and KennyP have said thanks
