Unidentified Gt
18 replies to this topic
#1 twostep OFFLINE
twostep
    Rockstar
  • 1,985 Thanks
  • 2,536 posts
Posted February 06, 2013 - 09:21 AM
Anyone have any idea what this is??
#2 jms180 OFFLINE
jms180
  • 1,513 Thanks
  • 1,564 posts
Posted February 06, 2013 - 09:28 AM
Any numbers or tags under seat bracket
#3 boyscout862 ONLINE
  • 12,843 Thanks
  • 9,166 posts
Posted February 06, 2013 - 09:41 AM
The bolt on rear wheels and the fender shape would have me guessing a late 70s MTD.
#4 twostep OFFLINE
twostep
    Rockstar
  • 1,985 Thanks
  • 2,536 posts
Posted February 06, 2013 - 09:45 AM
Nope, no ID's... it'a a CL find that I'm probably going to pick up if the rear end is any count. I know it's a shaft driven, hydro unit with hydraulic deck lift... Really those two things make it worth getting for me. To boot the front end looks like a solid piece for my wagon.
#5 Texas Deere and Horse ONLINE
  • 14,809 Thanks
  • 15,499 posts
Posted February 06, 2013 - 11:04 AM
It almost looks like a OMC mower. Let me look around a bit.
#6 twostep OFFLINE
twostep
    Rockstar
  • 1,985 Thanks
  • 2,536 posts
Posted February 06, 2013 - 11:26 AM
finally talked to the guy, he said it's a Duetz and he thought it was an 18hp so based on that and these pictures I think it's a Duetz-Allis 1918. (NOTE: these pic's are just google results for Duetz 1918)
Edited by twostep, February 06, 2013 - 03:44 PM.
  • Texas Deere and Horse and KennyP have said thanks
#7 twostep OFFLINE
twostep
    Rockstar
  • 1,985 Thanks
  • 2,536 posts
Posted February 06, 2013 - 11:37 AM
Looks like I'm going to pick this thing up...
#8 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted February 06, 2013 - 12:44 PM
Wasn't the Deutz equivalent to a Simplicity Sunstar?  If so, if I remember right, those are still pretty desirable tractors for work.
Ben Wagner
  • twostep and TAHOE have said thanks
#9 TAHOE OFFLINE
TAHOE
  • 7,975 Thanks
  • 5,674 posts
Posted February 06, 2013 - 01:19 PM
Ben Wagner
Yes, many people over look the Deutz because they were Allis brand, but basic same tractor as Sunstar which is pretty desirable.
2Step, any plans or just using rearend?
  • twostep and superaben have said thanks
#10 Texas Deere and Horse ONLINE
  • 14,809 Thanks
  • 15,499 posts
Posted February 06, 2013 - 02:22 PM
Wow, I hope you get it for a good price. Those were very heavy built GT's.
Here is some info on the trans.,
1. Reliable hydrostatic transmission.  A perfect complement to Kohler Magnum power! With direct shaft drive from engine. The Sundstrand 15 Series hydrostatic transmission has proven its reliability on larger tractors.
2. Massive transaxle. There is no better transaxle available in a garden tractor. Features automotive-type steel bevel gears and large diameter axles.
3. Super "Dual-Poise" stability.  Massive cast-iron steering axle improves lateral stabilia, through a unique double-pivoting system. This "Dual-Poise" front axle with rugged 1" diameter spindles provides a degree of ground-hugging performance conventional designs can't match plus tight 26' turning radius.
4. Single-lever hydraulic lift.  Raise or low ~ front, mid or rear attachments with fingertip ease, without special hydraulic extras. Dual hydraulic control with front outlets is optional.
  • KennyP and twostep have said thanks
#11 Texas Deere and Horse ONLINE
  • 14,809 Thanks
  • 15,499 posts
Posted February 06, 2013 - 03:11 PM
Cast-iron axle housing with ball-bearing-supported axle shaft provides greatest load-carrying capacity. Massive automotive type steel bevel gears mean extra-long life. Single range on 1918, Dual-range with differential lock on 1920.
  • twostep said thank you
#12 Texas Deere and Horse ONLINE
  • 14,809 Thanks
  • 15,499 posts
Posted February 06, 2013 - 03:13 PM
Bobby, You may want to just find an engine to drop in her. :thumbs:
Sounds like a Beast !!
#13 twostep OFFLINE
twostep
    Rockstar
  • 1,985 Thanks
  • 2,536 posts
Posted February 06, 2013 - 03:19 PM
Thanks guys. You all are right from what I've seen/read. It does not have power steering :( but it does have the deck lift. It does have a sunstrand 15 series rearend. It only has the single brake setup but the rear end is set up for duals. I plan to use the both axles and the lift cylinder/valve. I have no means to repower and no need/desire really. I didn't ask about a deck or hood but if he has them I'll see if I can fit them.
I'm heading that way at 4pm to get it... I'm in my car so might see a funny picture of me on the interenets somewhere.
Edited by twostep, February 06, 2013 - 03:20 PM.
#14 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted February 06, 2013 - 03:32 PM
we want pics of ur car adventure
#15 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted February 06, 2013 - 05:22 PM
Sounds like a nice score for some good parts. Good luck!
