How To Make Use Out Of The Rear Pto
11 replies to this topic
#1 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted February 05, 2013 - 05:18 PM
I was cruising the Cub Cadet side of the forum......saw this and went...ahhhh.....maybe if I posted it with here....Daniel, Brian and Titus (or others) could come up with something cool to do with our rear pto's!
http://gardentractor...bilt-groundsaw/
What can we run with a pulley or gear and chain????
  • 14,793 Thanks
  • 15,495 posts
Posted February 05, 2013 - 05:20 PM
I'm going to build a Bush Hog style pull type mower like Daniel and George have.
  • sacsr said thank you
#3 olcowhand ONLINE
  • 41,046 Thanks
  • 31,390 posts
Posted February 05, 2013 - 05:42 PM
If building a FEL, that rear pto would be an option for driving the hydraulics.  That way it could be kicked in & out easily, making it easier to start the engine.
  • caseguy, Texas Deere and Horse, sacsr and 1 other said thanks
#4 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted February 05, 2013 - 07:34 PM
The first cub cadet I ever saw with a pto was on my wifes grandfathers farm nd he used it to drive an elevator.
  • Alc and sacsr have said thanks
#5 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted February 05, 2013 - 08:31 PM
A backup generator is something that would be handy to have as well.
#6 Texas Deere and Horse ONLINE
  • 14,793 Thanks
  • 15,495 posts
Posted February 05, 2013 - 10:40 PM
Maybe I can drive a big fan off of it to blow air on me while I'm at a show riding around. :thumbs:  I would need a sun shade also then. :D
#7 Reverend Blair OFFLINE
Reverend Blair
  • 501 Thanks
  • 952 posts
Posted February 06, 2013 - 05:46 AM
I'd love a post hole digger for mine.  I haven't been able to find a 2000 RPM one though.  I've been thinking that with our soils it might be cool to build one where the PTO runs a hydraulic motor and that runs the PHD though.  That way you'd have reverse when it gets stuck.
#8 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted February 06, 2013 - 08:57 AM
Well you could build one snd the 2000 RPM might not be a barrier. Years ago My Dad took an old Truck Rearend. I think it had 4:11 gears in it and bilt a post hole digger and it worked pretty well.
#9 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted February 06, 2013 - 09:02 AM
Had another thought to throw out, though this was not on a Cadet. I used to drive by the Hagedorn Farm a lot. And every spring at planting time. He would have a 400 gal(?) Nurser Tank mounted on a Hay Rack, with a John Deere 112 siting next to it.
He had a Mule Drive mounted with a pump to agitate the Chemical mix and pump into his Sprayer tanks. He has done this for many years and it must work well.
#10 olcowhand ONLINE
  • 41,046 Thanks
  • 31,390 posts
Posted February 06, 2013 - 09:29 AM
Actually, that's not a bad idea, and would BE and look cool !
#11 Texas Deere and Horse ONLINE
  • 14,793 Thanks
  • 15,495 posts
Posted February 06, 2013 - 11:25 AM
:smilewink: I was serious !! :thumbs:
#12 KennyP ONLINE
  • 38,231 Thanks
  • 45,866 posts
Posted February 07, 2013 - 07:08 AM
Brian, get an older model fan and pulley off a car water pump. Make a shaft for it to spin on and hook up a belt to it. Put a cover over it and your done. Got AC on the GT!
