1st Annual Neogta Plow Day
oklahoma
68 replies to this topic
#46 olcowhand ONLINE
  • 37,841 Thanks
  • 30,378 posts
Posted February 25, 2013 - 09:30 AM
Looks like you did have a tough time with the hard soil.  I have 3 things to say....more weights, more weights,, then more weights!   :D
 The turf tires like on Mike's Allis do well if you chain them.  You guys also need to put a weight on the rear of the plow itself too.  Really helps getting/keeping the plow in the ground with tough soils.  If trash is a problem, take the coulters off.  Half the time I have to take mine off, or run them as high as possible.  Fill the rear tires, then add as much weight as you can, mostly on the left wheel.
  regardless of the tough plowing conditions, I'm sure you guys had a blast.  Next time you will be better aware of things to do ahead of time.  It does take some time to get things dialed in, so a 2 day event will help with that.
#47 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted February 25, 2013 - 10:07 AM
This is the first time most of these guys had plowed. I hope to have my CC setup next year and ready to plow. I am planning on taking the ags off the back of my MF10, mounting those on my extra rims. Buying some different Ags for it. (I had planned to buy Deestones all the way around, but somehow ordered Duro for the back.)
I plan to keep the tiller gearbox on the back, so I will have to order the extended Brinly hitch from xtememotorworks, and a different top pin. The top pin on my cub is setup for a tiller, so I will have to either remove it, or make an extension for it. The top pin is stuck and I cant get it out, so I may just make an extension for it.
Edited by Amigatec, February 25, 2013 - 10:08 AM.
#48 KennyP ONLINE
  • 33,756 Thanks
  • 43,011 posts
Posted February 25, 2013 - 10:13 AM
We're learning, Daniel! We just haven't had as much practice as you folks back East. I sent Mike an e-mail to see about doing a 2-day event before too long. The moisture we are getting now may help loosen the ground some more. Lower tire pressure could be a help. Filled tires would definitely help. I'll have to see what I can do for wheel weights. A little weight on the front might help.
Just a lot of things to work on.
  • JRJ said thank you
#49 skyrydr2 OFFLINE
  • 3,807 Thanks
  • 3,354 posts
Posted February 25, 2013 - 12:09 PM
 The Duros are my tire of choice ! They bit AWSOME !! I love  them and they are WAY less expensive too!!
#50 MH81 ONLINE
  • 29,718 Thanks
  • 29,663 posts
Posted February 25, 2013 - 12:17 PM
Very Glad you guys had a good time.  Getting plows "Tuned" can be a balancing act and it has  to be done almost every event you go to.
We go to three plow days each year and they are all WAY different.  Danville is the best of the three for soil conditions, but the other two are different also.
Just takes some getting used to to figure out what's what.
#51 daytime dave OFFLINE
  • 4,586 Thanks
  • 6,414 posts
Posted February 25, 2013 - 01:12 PM
That looked like a great plow day.  I really am glad to see that DB working.  Kenny's FF did a great job for those tough conditions.  That looks like a winner Kenny.  A little weight and you will be a plowing machine.
It didn't look like anyone had chains on.  That would have helped the turf tired tractors I would think.
#52 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted February 25, 2013 - 01:32 PM
The ruts where I was dissing were deep, I was trying to stay between them. It was bouncing all over the place. The governor was working perfect.
#53 olcowhand ONLINE
  • 37,841 Thanks
  • 30,378 posts
Posted February 25, 2013 - 01:55 PM
I forgot to post about that.....looks like you got more of a workout than you wanted!  I'll stick to a seat!  :smilewink:
  • KennyP and Amigatec have said thanks
#54 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted February 25, 2013 - 02:03 PM
I for got to post about that.....looks like you got more of a workout than you wanted!  I'll stick to a seat!  :smilewink:
Between the ruts and the windrows I was doing good to keep it from turning over. Part of the time I was on one wheel.
#55 HowardsMF155 OFFLINE
  • 2,750 Thanks
  • 2,936 posts
Posted February 25, 2013 - 03:18 PM
Who brought the Gravely?  Looked like it was running good, but it really needed to be a slower model or else have geared wheels.  It certainly looked good.   You know the sod is tough when a gravely is throwing out sod clods instead of pulverized dirt
#56 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted February 25, 2013 - 03:23 PM
We have a bigtime Gravely collection buyer seller in the area. This one was assembled from pieces. He also bought his sulky with it.
#57 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted February 25, 2013 - 04:11 PM
We have 3 members over here in N.W. Arkansas that may be able to get together and come as observers only at one of the future events. I will have to throw it up to them and see what they say and then the dates will play a big part of this for us.
Thank for all the pictures and the video.
Dick
#58 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted February 25, 2013 - 04:53 PM
That would be great!!!!
#59 mowinman2 OFFLINE
mowinman2
    Always on the Hunt
  • 197 Thanks
  • 243 posts
Enjoyed that video and the pics.  Thanks for sharing.  Looks like 18 tractors is a great turn out for a winter plow day.  I saw a short clip on Facebook that NEOGTA had posted.  Im glad I got to see more here.
Like Daniel suggested, I would be investing in some weights.  Even if you do the home made route with gym weights, anything will help keep that traction.  I know Miller tire sells the valve you can screw on the valve stem to fill your tires with liquid.  Thats also a big help, and much, much cheaper than weights.
#60 DH1 OFFLINE
DH1
    Electric Tractors
  • 4,958 Thanks
  • 5,444 posts
Posted February 25, 2013 - 05:26 PM
Good stuff guys, looked like you had a good day, wish I could of been there with ya.
Thanks for the pictures and the video. :thumbs:
Also tagged with one or more of these keywords: oklahoma
