Ntm Massey Mf-14 (1974)
164 replies to this topic
#106 DH1 OFFLINE
DH1
    Electric Tractors
  • 5495 Thanks
  • 5633 posts
Posted February 12, 2013 - 06:32 PM
Mine
  • IamSherwood and Moosetales have said thanks
#107 broken2 OFFLINE
broken2
  • 280 Thanks
  • 425 posts
Posted February 12, 2013 - 06:50 PM
DH1 beat me to it but since I have the pics I'll add them. This is the stick out of my mf14 and it matches DH1's. You can be certain you have the right lengths now!
If you haven't filled it yet I suggest you put the fluid someplace warm so it will be thinner and pour easier, these are a pain to fill.
  • DH1, IamSherwood and Moosetales have said thanks
#108 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1090 Thanks
  • 1284 posts
Posted February 12, 2013 - 07:32 PM
Don't laugh but I have a crock pot set up in the garage (on low of course) for warming the fluid.......shhhhhhhhh........don't tell my wife. :D
  • MH81 and IamSherwood have said thanks
#109 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted February 12, 2013 - 07:42 PM
:wewantpics:
Just so I have ammo, next time the wife chases me with the broom, for doing
something like that. :D
  • Moosetales said thank you
#110 Moosetales OFFLINE
Moosetales
  • 1090 Thanks
  • 1284 posts
Posted February 12, 2013 - 07:57 PM
Okay, here's your ammo:
And here are their cousins:
You all would be proud.....of my wife that is.......she knows now and is actually cool with it. Of course I was smart enough to use the back up pot instead of her really nice big one; the big one was tempting as I could have put all 5 quarts in that one at once. I'd like to live to see another day. :bigrofl:
  • broken2 and IamSherwood have said thanks
#111 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted February 12, 2013 - 08:03 PM
Thanks, it's in the vault.
Very good of the Mrs. to let you play with her stuff. :thumbs:
#112 Moosetales OFFLINE
Moosetales
  • 1090 Thanks
  • 1284 posts
Posted February 12, 2013 - 11:57 PM
Well guys you inspired me to find a way to speed up the process of filling my transmission on the tractor. ATF pre-heated in the crock pot till it's nice and warm in conjunction with an in-line pump, powered by a drill, and a little practice and the result was 1 quart in about a minute. I learned on the first quart to fill in "spurts" to allow the air to "burp"out as the transmission fluid goes down the hatch. Here's a quick look see:
Thanks for the inspiration.
  • broken2, Texas Deere and Horse, IamSherwood and 1 other said thanks
#113 Moosetales OFFLINE
Moosetales
  • 1090 Thanks
  • 1284 posts
Posted February 13, 2013 - 08:31 PM
I was able to capture a video of putting two quarts of ATF in the Massey. I put the first *quart in slower than the second quart. I decided to push the envelope on the second quart just to see what would happen. If I had put a towel over the end of the transmission fluid fill tube I would have avoided the splash. Even with the spray after finishing the second quart I only lost a small amount of fluid (captured it in a metal dish...see below).
Lost fluid from second quart:
I'd say the time saved in getting the fluid in the transmission far out weighed the lost fluid.
* The only way I see this method working is if you warm the ATF before pumping it into the system
  • broken2 said thank you
#114 Moosetales OFFLINE
Moosetales
  • 1090 Thanks
  • 1284 posts
Posted February 13, 2013 - 09:11 PM
BTW, here's the solution I came up with for the burp induced over spray when pumping the ATF in at high speed:
It's a medicine container with a hole cut in the center of the bottom. The diameter of the container is exactly the outer diameter of the fill tube.
  • Texas Deere and Horse, IamSherwood and Cat385B have said thanks
#115 Texas Deere and Horse OFFLINE
  • 15109 Thanks
  • 15570 posts
Posted February 14, 2013 - 12:38 AM
Good idea Moose, way to work the problem !! :thumbs:
#116 Moosetales OFFLINE
Moosetales
  • 1090 Thanks
  • 1284 posts
Posted February 14, 2013 - 06:43 AM
ROOKIE MISTAKE? In all my haste (and excitement) to get the ATF into my Massey I neglected to change the filter while I had the system drained. :(  So, do I need to drain the ATF out before changing the filter or does the filter have enough elevation that I can change it without having to drain the system? Thanks. :worshippy1:
#117 Moosetales OFFLINE
Moosetales
  • 1090 Thanks
  • 1284 posts
Posted February 14, 2013 - 06:58 AM
:wewantpics:
Not only did my wife let me use the crock pot but I walked into the garage last night and there on the floor of my shop was a NTM crock pot....okay, maybe it had to do with the fact she already has another one and the thought of cooking up a stew in the same pot 5 quarts of ATF were warmed in wasn't the yummiest thought she'd ever had.
If you all need to borrow my professional "fluid warmer" just give me a holler. :thumbs:
#118 KennyP ONLINE
  • 50110 Thanks
  • 52289 posts
Posted February 14, 2013 - 07:09 AM
I have a good stock of "fluid warmers". Can't help you on the filter change out though. Is there not a vent on these trannys? That would help the fluid go in better.
#119 Moosetales OFFLINE
Moosetales
  • 1090 Thanks
  • 1284 posts
Posted February 14, 2013 - 07:24 AM
Re: the vent. I haven't found one and if there is the guys haven't told me about it.....and are sitting back :bigrofl:.
Edited by Moosetales, February 14, 2013 - 07:28 AM.
#120 KennyP ONLINE
  • 50110 Thanks
  • 52289 posts
Posted February 14, 2013 - 07:27 AM
It would seem there would be one, as it heats up it will build pressure inside. What transaxle is in these?
