Ntm Massey Mf-14 (1974)
164 replies to this topic
#76 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1090 Thanks
  • 1284 posts
Posted February 09, 2013 - 02:55 PM
At least it didn't just throw it. Looks like it went through the blower!
While I was putting it back on...after I threw it the first time...I noticed several LARGE cracks so I knew she'd probably blow. The rest of the belt is still on the thrower so I'm pretty sure the belt never got close to the auger....thank goodness.
  • MH81 and IamSherwood have said thanks
#77 KennyP ONLINE
  • 50962 Thanks
  • 52632 posts
Posted February 09, 2013 - 03:06 PM
You'll be finding bits and pieces next Spring!
  • Moosetales said thank you
#78 Texas Deere and Horse OFFLINE
  • 15111 Thanks
  • 15570 posts
Posted February 09, 2013 - 04:57 PM
OK Moose, you are in the clear now. :thumbs: I needed to read more posts to catch up on the Massey issues. :wallbanging:
Sorry you lost the belt, but MAN that thing was throwing the snow out there, doing a good job from what I could see. :dancingbanana:
Thanks for posting!
#79 Trav1s OFFLINE
Trav1s
  • 4094 Thanks
  • 4920 posts
Posted February 09, 2013 - 07:29 PM
The first time out with a new machine is always an adventure.  :D   Sounds really good!
#80 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted February 10, 2013 - 09:53 AM
Oh, that's too bad, about the belt taking the 14 out of the action.
On the bright side, now you can go over it, with a fine toothed comb, so it works
flawlessly for the next snowfall.
#81 Moosetales OFFLINE
Moosetales
  • 1090 Thanks
  • 1284 posts
Posted February 10, 2013 - 04:47 PM
The sun is out....temps are warm(er)......and I got a chance to take a real good look at the Massey this afternoon. Here's what I found:
The manual says, "Check dipstick under seat, when oil is cold, to make certain transmission, differential and hydraulic system are properly filled with M-1110." Ummmmmmm, glad the belt broke cause I made a rookie mistake and neglected to check the transmission/hydraulic fluid level and I'm not sure it was at full capacity. This is what I found.
Dipstick.....didn't think they were as short as this one is and I've never seen one where the end is slanted (as if it's been broken off) and that doesn't have an indicator when Full. Obviously I could not determine the level of the fluid since I did not have a proper length stick, so I drained the transmission.
The top of the plug had some pretty gunky sediment on it (left smear below).
The plug its self is magnetic.......just learning this today.......and had collected a plethora of tiny metal fragments (from where I do not know).
So the transmission is drained. I've just learned that M-1110 is MF version of ATF (such as Dexron III ATF).
Next, I found another oddity, there is a about an 1/2" to 1" space between the hood and the dash. Hmmmmmmm?
Upon closer examination I also noticed that lift mechanism (I think that's what it is) that connects to the mower deck (again, I think that's what it is) is not centered in the hole in the frame where it's intended to go (this is on the left side of the tractor when sitting in the seat)
Notice that this pin (best word I could come up with) is not sitting in the hole as it's suppose to (same side of the tractor just the front "pin).
You might be able to notice in the pictures below how some of the "pins" on the left and right side of the tractor (down where my feet will go) are centered and straight while others are out of their holes and not aligned properly.
I'll also post a video in a bit that shows the large amount of play in the steering wheel that I need to address.
So, I appreciate your feedback and help in unraveling these mysteries. Thanks.
Edited by Moosetales, February 10, 2013 - 10:45 PM.
#82 josh deaven OFFLINE
josh deaven
  • 480 Thanks
  • 574 posts
Posted February 10, 2013 - 05:30 PM
What a great find! You have a really nice Mf 14.It is always cool to find those hidden gems.Congrats and enjoy. I believe your mf is so nice I would not restore it. I would keep up on the mantence and enjoy.  :thumbs:
Edited by josh deaven, February 10, 2013 - 05:33 PM.
#83 pianotuner OFFLINE
pianotuner
  • 92 Thanks
  • 140 posts
Posted February 10, 2013 - 06:29 PM
The hood is a simple adjustment of the grill angle.  I'm guessing the pins could be spot welded in place.
#84 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted February 10, 2013 - 07:47 PM
I thought I had a paper copy of the snowthrower manual, but I guess I don't. Looked everywhere.
What I did find in my laptop, was a manual for the Snapper 4220 thrower.
Alot of similarities. maybe that's what I was thinking about.
  • MH81 and Moosetales have said thanks
#85 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted February 10, 2013 - 08:25 PM
I am wondering if when you get all those pins lined up, if the frame won't pop back in place... :D
I think (if it's like the lift bkts on the 12h) that the rods, spacers, and frame width all work together to keep stuff in place.
I agree that if stuff won't stay, you may have to spot weld, but with as good as everything else looks, it might just be as simple as putting everything right.
#86 coldone OFFLINE
coldone
  • 1716 Thanks
  • 1709 posts
Posted February 10, 2013 - 09:27 PM
Your tranny has ATF in it. I cant remember what type though.
#87 Trav1s OFFLINE
Trav1s
  • 4094 Thanks
  • 4920 posts
Posted February 10, 2013 - 09:36 PM
JD's use Type F in the hydros.
#88 Moosetales OFFLINE
Moosetales
  • 1090 Thanks
  • 1284 posts
Posted February 10, 2013 - 10:20 PM
Oh boy I'm confused. The manual references using M-1110 but then below that it states, "NOTE: 10W/40 engine oil (API Service Classification "SE" or "CC") is recommended for heavy-duty or high temperature operation." My Case takes motor oil (I use Rotella) in the hydro system so I guess I'm mixing my machines up.
Does your JD take 10W/40 (or some kind of engine oil) for high heat or heavy-duty operation? Guess I need to search for M-1110 and see what that stuff is.
#89 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted February 10, 2013 - 10:35 PM
I use Dexron III ATF in mine. I think most guys do.
M-1110 would be MF's fluid. I've never seen it myself.
#90 Moosetales OFFLINE
Moosetales
  • 1090 Thanks
  • 1284 posts
Posted February 10, 2013 - 10:40 PM
The manual says the max capacity is 5 quarts. I presume I'm reading that correctly? Since I have 3/4 of a dipstick (not sure what happened to the rest....unless all MF dipsticks are as short as mine pictured previously) I won't be able to check the fluid level until I can land myself a new dipstick. Thanks.
