Diesel Engine For A Tractor?
diesel engine
This topic has been archived. This means that you cannot reply to this topic.
10 replies to this topic
#1 boyscout862 OFFLINE
  • 13,559 Thanks
  • 9,433 posts
Posted February 03, 2013 - 07:54 PM
I came across this and was interested if it would fit on my HT23 which ran but is in poor condition.
http://newlondon.cra...3591204034.html
3I23Nb3H95Kb5H25Jbd239bf34e4924c31452.jp
IT doesn't run and they want $500 for it.
#2 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted February 03, 2013 - 08:04 PM
Thats not a bad price for it considering it doesnt run? Could be the injecter pump is messed up and might need adjusted. Im not too familiar with cummins though i didnt know they made a 3 cylinder model?
#3 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted February 03, 2013 - 08:20 PM
$500 seems a bit much for the non runner (IMO) being it is from a boat (in our area) it is highly likely these were salt water cooled engines. They have heat exchangers and water jacketed exhaust manifolds on them, so there would be some modifying right there.
Plus you never know if these came from a salvaged (sunk) boat.
If I were to look into these I would ask him if they were salt or fresh water cooled engines.
#4 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted February 03, 2013 - 09:21 PM
The crankshaft is probably tapered as well, for use with a single bearing alternator.
#5 boyscout862 OFFLINE
  • 13,559 Thanks
  • 9,433 posts
Posted February 03, 2013 - 09:22 PM
Chris by the looks of the other pics they were salt water. Thanks for the heads up. I'll bet they were salvaged from something the hurricane sank.
#6 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted February 03, 2013 - 11:47 PM
My first big boat was a 42' Luhrs Sport Fisher with twin Chrysler 318"s. It was also salt water cooled. It is amazing how the engine manifolds and heat exchangers can look like new on the outside but actually be paper thin on the inside form years of salt water as cooling.
And you brought up a great point! After the hurricane we have to be even more careful buying things.
#7 boyscout862 OFFLINE
  • 13,559 Thanks
  • 9,433 posts
Posted February 04, 2013 - 10:26 AM
I believe we've had 4 major storms in the last year and a half. There is a lot of cars and trucks that went under too. It is funny that thinking about that Cummings reminded me that I have a small 4 cylinder FORD diesel generator in my basement(buried behind 2 other big generators). I'll have to try and dig it out.
#8 Cvans ONLINE
  • 7,308 Thanks
  • 6,392 posts
Posted February 04, 2013 - 12:11 PM
The folks above have brought up some good points to check into. Tapered crankshaft and cooling jackets. Also if you have to start replacing the fuel system components your investment is going to go up in a hurry. In my opinion I would leave these and look for a running diesel that wasn't marine orientated.  Not being in a hurry and asking lots of questions can save you hundreds of dollars.
#9 braxx OFFLINE
braxx
  • 20 Thanks
  • 45 posts
Posted February 04, 2013 - 12:21 PM
Plus being from a generator it is probably a governed fixed engine speed. Sent from my SPH-L710 using Tapatalk 2
#10 Texas Deere and Horse ONLINE
  • 14,889 Thanks
  • 15,514 posts
Posted February 04, 2013 - 12:53 PM
Can you change a fixed speed engine to a variable speed engine? I have a deal  working on a couple out of reefer cooler units. Is it a matter of hooking up a throttle cable or is it internal?
#11 Cvans ONLINE
  • 7,308 Thanks
  • 6,392 posts
Posted February 04, 2013 - 06:26 PM
The ones I've done only required backing out the stop screws on the throttle arm and installing a throttle cable to the dash. Some may require changing the governor springs and that could be internal.
