Ht20d P.t.o Belt Swap?
ht20d
10 replies to this topic
#1 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted February 03, 2013 - 10:49 AM
hi guys. i was looking at my HT20D this morning and realized theres on 1 out of 3 belts that are supose to be on there to enguage the p.t.o. also the the idler pully went bad at some point in its life and now is just the bearing sleeve. there is a brake strap that goes around the p.t.o so i guess i have to remove that to get the belts off? onfo on parts and how to get them would be great. thanks sam
  • 15109 Thanks
  • 15570 posts
Posted February 03, 2013 - 11:09 AM
Sam, Check with the Site Sponsors, one of them should be able to help you out.
Good Luck!! :thumbs:
#3 wilberj OFFLINE
wilberj
  • 5547 Thanks
  • 5736 posts
Posted February 03, 2013 - 11:10 AM
You can get the parts at a auto parts store take the belt with you two and get the green power belts.
The shield on the pto pulley and the little rod the goes over the idler pully is what is needed to  be taken off.
  • Texas Deere and Horse and 1967bolens collector have said thanks
#4 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted February 04, 2013 - 07:27 AM
if the pulley part number 1713802? its the closest thing i could find that loooks right on bobs web site
#5 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted February 04, 2013 - 09:46 AM
In my HT22/HT20D parts manual, the Idler Sheave is listed as part# 1719 202
It's also the same part# for the HT23.
#6 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted February 04, 2013 - 09:37 PM
i got the parts ordered from bob today so hopefully i willl have them at the end if the week alot more money then ithought but going to need them for trenching:)
#7 bhts OFFLINE
bhts
  • 1493 Thanks
  • 2181 posts
Posted February 05, 2013 - 12:17 PM
Thanks for the order.We also took care of the GTTalk discount for you.
  • 1967bolens collector said thank you
#8 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted February 06, 2013 - 08:23 AM
thanks again bob and we might be comeing this weekend or next we arnt 100% sure yet im looking foward to stoping in
Edited by 1967bolens collector, February 06, 2013 - 08:23 AM.
#9 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted February 09, 2013 - 10:15 AM
well i got my parts 2 days ago for the HT20D and who ever owned it before ken they kept running it with a bad bearing until that pully cane out an it ruined the shaft :firejumper:  when it came out you can see where it hit the edge of the fly wheel nd theres 6 or 8 alan bolts that hold the flywheel  screen it broke the head off one and bent 1 or 2. that had to make a BIG BANG when that sucker came out but i got a new shaft comeing thanks to bob so now when i get it back together i hope i dont have any issues with it an im going to keep a close eye on that pully.. i also adjusted the valves because the motor was tapping but it was just from the rocker arm being way to loose so i got that issue fixes along the way :thumbs:
#10 NJKen OFFLINE
NJKen
  • 1362 Thanks
  • 1284 posts
Posted February 10, 2013 - 07:35 AM
Sam, I'm real sorry that this happened. I never used the PTO since the plow was mounted when I bought it and it never came off to use the mower deck.
I can assure you, I did not know there was a problem with it.
#11 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted February 10, 2013 - 01:53 PM
its all good its a easy fix just cost 125 bucks
Also tagged with one or more of these keywords: ht20d
