1982 314 Finds New Home
138 replies to this topic
#61 nade-em OFFLINE
nade-em
  • 202 Thanks
  • 171 posts
Posted February 25, 2013 - 07:36 PM
:D I found a big mouse nest in my hydro fan housing. I got out the pressure washer yesterday and blasted everything clean, looks much better now.
ETA: check your petcock, i found out tonight that mine was busted after it spewed 3 gallons of gas all over my garage floor! -----Sooooo close, yet so far. :wallbanging:
Edited by nade-em, February 25, 2013 - 07:48 PM.
  • Trav1s and larryd have said thanks
#62 Trav1s OFFLINE
Trav1s
  • 3,648 Thanks
  • 4,603 posts
Posted February 25, 2013 - 11:53 PM
I will be sure to check the shut-off valve on the tank before I bolt it together.  The old line was very hard and I could not get it off the fuel pump and shut-off valve without cutting it off.  I have new fuel line from NAPA in its place too.
  • larryd said thank you
#63 Trav1s OFFLINE
Trav1s
  • 3,648 Thanks
  • 4,603 posts
Posted February 25, 2013 - 11:55 PM
Looking sad right now
#64 Trav1s OFFLINE
Trav1s
  • 3,648 Thanks
  • 4,603 posts
Posted February 26, 2013 - 11:50 AM
Just ordered the yoke and petcock from Deere.  Looks like I need to get to work on the carb so it is rebuilt before the parts are here.
#65 nade-em OFFLINE
nade-em
  • 202 Thanks
  • 171 posts
Posted February 26, 2013 - 08:09 PM
Looks like mine. Seems like every tool i own is right next to the JD ! :D
#66 Trav1s OFFLINE
Trav1s
  • 3,648 Thanks
  • 4,603 posts
Posted February 27, 2013 - 07:12 AM
My garage is especially bad with the 120 and 314 as well as the parts from two 1968 Plymouth Furys lurking around.  It looks like the master of disaster has take up residence in there... :bigrofl:
#67 Deere Green OFFLINE
Deere Green
  • 24 Thanks
  • 126 posts
Posted February 28, 2013 - 10:24 AM
looks good and like you are tearing it to that thing pretty well.  drive shafts are a pain.  just did mine a few months back and it only took about an hour and  a half to pull the engine and put it back together, only tough part was the pin that holds the shaft on the hydro side for me.  it was stuck in there pretty good.  good luck!
#68 Trav1s OFFLINE
Trav1s
  • 3,648 Thanks
  • 4,603 posts
Posted March 08, 2013 - 08:02 PM
Finally got some garage time today.  I finished the fuel system with new hose, a fuel filter, shut-off valve and carb rebuild.  It it not initially fire when I hit the key because I got lazy and did not gap the points.  So with my finely calibrated eye I set the gap and gave it a try.  We have fuel and fire!!!!   Now to get the high side and low idle fine-tuned.  Definitely shakes a bunch at low idle... which is too low.
Edited by Trav1s, March 08, 2013 - 11:20 PM.
  • KennyP and larryd have said thanks
#69 Trav1s OFFLINE
Trav1s
  • 3,648 Thanks
  • 4,603 posts
Posted March 08, 2013 - 11:11 PM
Here are pics of the seat and fender pan after simple green and a brush. Looks better than I expected.
#70 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted March 09, 2013 - 05:56 AM
Glad it fired up for you. Parts look nice all cleaned up!
#71 nade-em OFFLINE
nade-em
  • 202 Thanks
  • 171 posts
Posted March 09, 2013 - 07:43 PM
Good Job! How'd it run? Looks like we're in a race or something! :beerchug:
#72 Trav1s OFFLINE
Trav1s
  • 3,648 Thanks
  • 4,603 posts
Posted March 10, 2013 - 08:09 AM
Runs pretty good considering I have not fine-tuned the carb, replaced the plug, or set the gap on the points.  The more I spend time with it the more I believe it was long-blocked in the spring of 98.  I think it will run smoother and smoke less once all that is done.  I put a bit of ATF in the combustion chamber a week ago.  That is an old school trick to free stuck rings and reduce carbon in the combustion chamber. I will give it a dose of Seafoam when I put it to work.
Here is the 2nd start-up hosted instead of attached as a mov file:
th_3C0C8BB4-1FC7-4DC6-B658-0E28E8F4915D-
As I was poking around doing the repairs I definitely see the roots of the 300 series in the 120/140's.  I have mentioned this before but to repeat it again - The size difference was also a big surprise to me.  I am happy with the smaller size of the 120 for what I do and don't regret my choice.  I could change my mind when I put the 314 to work. :rolling:
The seat is in excellent condition and will stay with me if the tractor finds a new home.  I know where there is a parts 112 sitting in town.  The paint is definitely oxidized but still green. :dancingbanana:  This would be a perfect worker with a bit of real-life patina. :smilewink:
Edited by Trav1s, March 10, 2013 - 08:12 AM.
#73 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted March 10, 2013 - 08:36 AM
I use a bit of MMO in the oil to help with carbon and stuck rings. Helps clean out the crankcase, too.
#74 Trav1s OFFLINE
Trav1s
  • 3,648 Thanks
  • 4,603 posts
Posted March 10, 2013 - 08:47 AM
Never tried MMO. How much do you add?
#75 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted March 10, 2013 - 08:57 AM
Their site recommends 10% to 25%. I wouldn't use the 25% for a long time in there, myself. But 10% would be good if you want to run it for several weeks I would think.
