T92, Front End & Differential I.d.
15 replies to this topic
#1 NeedMoreStuf OFFLINE
NeedMoreStuf
  • 72 Thanks
  • 46 posts
Posted February 02, 2013 - 05:16 PM
Got these from a friend of mine the other day, I know the trans is a Crosley type but from what tractor? I havnt been able to find this bellhousing and clutch set up on the internet and would that be a parking brake assembly on the tail? There is still quite a bit of what appears to be the original green paint (Bolens?). The front end from what Ive found appears to be Power King Economy but from what model and or year range? The differential Ive drawn a blank on, it has 4.55 gears and the ring gear is marked Salisbury 16417  12CL (or i) 41-9 Y.
Thanks for any help with these.
#2 DougT OFFLINE
DougT
    Dog Approved
  • 6,928 Thanks
  • 4,996 posts
Posted February 02, 2013 - 06:11 PM
The trans and clutch looks to be from the Shaw riding lawnmower.
  • NeedMoreStuf said thank you
#3 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted February 02, 2013 - 07:11 PM
There's nothing in those pictures that belong to an Economy.  Pieces are similar (tranny, punkin on the rear end) but that's about it.  Those parts were off of something else.
#4 NeedMoreStuf OFFLINE
NeedMoreStuf
  • 72 Thanks
  • 46 posts
Posted February 02, 2013 - 07:24 PM
The mystery continues...........
#5 Gtractor OFFLINE
Gtractor
    G-agressive tractor
  • 9,335 Thanks
  • 4,956 posts
Posted February 02, 2013 - 09:47 PM
DougT has it - Shaw riding mower.  You can make anything with a setup like that. VERY NICE!!!!
http://www.antiquetr...ll&what=gphotos
Edited by Gtractor, February 02, 2013 - 09:54 PM.
#6 glgrumpy OFFLINE
  • 8,617 Thanks
  • 7,923 posts
Posted February 02, 2013 - 10:30 PM
I agree, not Economy axle. That trans shifter top seems to be on backwards?? Wouldn't think the gears would line up to the forks. Does it appear to shift?  OR, maybe trans has clutch behind it? and engine powers from back?? What's it say on the red tag, can't read that.
#7 NeedMoreStuf OFFLINE
NeedMoreStuf
  • 72 Thanks
  • 46 posts
Posted February 02, 2013 - 11:18 PM
I think you hit it too with that photo Kris, I just cant quite make out what engine that is and in trying to do an internet search I cant find any other photos of that type of Shaw mower. The top cover only fits the one way, although it may look a little odd I believe its suppose to be "backwards". It shifts good and just need the grease changed, the internals look to be in nice condition. The tag reads something like "Keep hands and feet clear of mower".
#8 DougT OFFLINE
DougT
    Dog Approved
  • 6,928 Thanks
  • 4,996 posts
Posted February 02, 2013 - 11:26 PM
I think the Shaw used an AKN Wisconsin.
#9 Texas Deere and Horse OFFLINE
  • 14,814 Thanks
  • 15,501 posts
Posted February 02, 2013 - 11:27 PM
With what you have, you can built any kind of GT, or Sub Compact you want. Good Luck on your search and build.. :thumbs:
#10 NeedMoreStuf OFFLINE
NeedMoreStuf
  • 72 Thanks
  • 46 posts
Posted February 02, 2013 - 11:34 PM
Just found this one. Note the shifter. Ive got a Very nice 1965 Wisconsin AENLD, I'll have to see what will bolt up to the bellhousing, or what I can adapt it to.
#11 Texas Deere and Horse OFFLINE
  • 14,814 Thanks
  • 15,501 posts
Posted February 02, 2013 - 11:38 PM
Never seen one of those before. You have found it. Now you can start to Fab the rest of it or build something else. :thumbs:
#12 DougT OFFLINE
DougT
    Dog Approved
  • 6,928 Thanks
  • 4,996 posts
Posted February 02, 2013 - 11:42 PM
Here is one that sold on ebay recently. There were 2 different sizes but I'm not sure if the driveline was the same or not.
http://www.ebay.com/...cvip=true&rt=nc
  • Texas Deere and Horse and NeedMoreStuf have said thanks
#13 Ryan313 OFFLINE
  • 3,368 Thanks
  • 5,231 posts
Posted February 03, 2013 - 04:52 PM
It looks like the mystery is solved! That is a pretty cool little mower and the drive line is definitely overbuilt for something that size!
GL, the trans cover is on the right way, the shifter is just bent forward. It is much like the rear shifter on a PK with two transmissions.
#14 DougT OFFLINE
DougT
    Dog Approved
  • 6,928 Thanks
  • 4,996 posts
Posted February 03, 2013 - 05:09 PM
We still need to figure out what the front axle and diff came out of. They didn't come off the mower. The front axle is unique in the fact that each side is seperate and bolted to the pivot in the middle. Not many did that. If we can find the one that did, I'd say we found it.
#15 NeedMoreStuf OFFLINE
NeedMoreStuf
  • 72 Thanks
  • 46 posts
Posted February 03, 2013 - 09:07 PM
Thanks DougT, yeah Im obviously still interested in finding out what the front and diff. are from. The search goes on.
