Soap Bubbles!
21 replies to this topic
#16 Deere Green OFFLINE
Deere Green
  • 24 Thanks
  • 126 posts
Posted February 04, 2013 - 10:05 AM
That stuff IS the answer!  Dad uses it at his shop all the time on aluminum wheels.
may need to try this as i have this issue on the truck now and it is a pain.  alum wheels and salt have been an issue with every set of rubber i have put on.
  • Trav1s, CRFarnsworth and larryd have said thanks
#17 UncleWillie ONLINE
  • 16,255 Thanks
  • 8,974 posts
Posted February 04, 2013 - 08:59 PM
When I saw the title I thought you had made a bubble blower for the parade already. I have a tire on the DragonFly that will not seal. I have to air it up every time I use it. Might try Kennys goo. or an inner-tube.
  • CRFarnsworth and larryd have said thanks
#18 MH81 OFFLINE
  • 29,979 Thanks
Posted February 04, 2013 - 09:14 PM
It's a shame Lawrence Welk isn't with us anymore... He would've bought the tire off you.
Good luck on sealing it.  Sometimes you get lucky and the solution is external.
#19 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted February 14, 2013 - 10:56 PM
Slime works fairly well.
larryd
#20 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted February 15, 2013 - 07:12 PM
I always have this old school stuff around for gaskets, and yes it seals beads too.80057.jpg
#21 MH81 OFFLINE
  • 29,979 Thanks
Posted February 15, 2013 - 08:57 PM
I always have this old school stuff around for gaskets, and yes it seals beads too.attachicon.gif http://gardentractor...59569]80057.jpg[/url]
Oh, so YOU are the dirty rotten SOB that I was screaming at last time I found that brown stuff on a bead after hammering on it for an hour...
:poke:
J/K, you're right, it does seal. :D
#22 grnspot110 ONLINE
grnspot110
  • 4,323 Thanks
  • 2,696 posts
Posted February 15, 2013 - 10:25 PM
larryd
Just be aware that some of the "hydro sealants" are corrosive!  When I bought my JD 420, one front tire leaked, took it off to find a hole eaten through the rim!
 Cleaned the rim, epoxied the hole, re-painted & used a tube in it.  No more sealants for me!  ~~  Lowell
