David Bradley Tree Saw
31 replies to this topic
#16 KC9KAS ONLINE
KC9KAS
  • 5,443 Thanks
  • 4,710 posts
Posted February 02, 2013 - 08:24 PM
Very nice....Hope you get it operational soon.
I used a "mower" of sorts that was very much like this DB saw, except instead of the saw blade, it had a regular mower type blade.....and no guard. This was the mower we used at the city park to mow around post and the like before weed-eaters. It was called "The Man Killer", although no one that I know of was ever hurt with it.
#17 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted February 10, 2013 - 12:59 PM
Well I removed the head today, and I think the rings are stuck. The wall look, the spark plug was loose and that probably allowed water to get in. Also I took the clutch apart and it look like its all there. I counted 12 balls, I was only expecting 10.
#18 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted February 19, 2013 - 04:09 PM
Good news I have been able to slightly rotate the motor, I can move the piston up and down maybe 1/4". So I'll give it more time and more soak.
Edited by Amigatec, February 19, 2013 - 04:09 PM.
#19 KennyP OFFLINE
  • 40,036 Thanks
  • 46,727 posts
Posted February 19, 2013 - 04:45 PM
That's good news, Pat! Soak it some more!
#20 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted February 26, 2013 - 04:20 PM
Well I'm able to spin the motor by hand now somewhat, I can get about a half turn and it gets solid. Time to pull the pan and have a look.
#21 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted February 26, 2013 - 04:55 PM
OK I found the problem. One of the bolts holding the fan shroud on was to long and hitting the flywheel. I can spin it by hand now.
#22 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted February 26, 2013 - 06:28 PM
Its always nice when you find that the problem is nothing major. Glad you got her loose!
#23 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted February 26, 2013 - 06:40 PM
I need to remove the nut holding the starter cup on, so I can remove the shroud.
The shroud is rusted out on the bottom and the intake tube for the shroud is also rusted out. I may be able to fix it.
#24 KennyP OFFLINE
  • 40,036 Thanks
  • 46,727 posts
Posted February 27, 2013 - 08:39 AM
Glad you are making headway, Pat. Good luck with it!
#25 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted February 27, 2013 - 09:20 AM
I plan to work on it today some.
#26 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted February 27, 2013 - 02:31 PM
Well I got the nut off the end of the flywheel, good thing I asked, it IS left hand thread.
But the flywheel has 4 broken fins. I found another one for $65.
I just need to figure out how to pull it.
#27 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted February 27, 2013 - 03:23 PM
Flywheel is off, it's a good thing the flywheel key was about 1/2 sheared.
It's amazing how many parts I can still find for it. So far have located almost every part I need.
#28 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted February 27, 2013 - 04:22 PM
#29 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted February 27, 2013 - 08:28 PM
More pictures of the B&S 8.
In one picture you can see the ducting that goes on the front of the motor. This is used to provide clean air for cooling, so the fins don't get clogged with debris. You can see me pointing to the felt seal in the center.
#30 bowtiebutler956 OFFLINE
bowtiebutler956
  • 660 Thanks
  • 796 posts
Posted February 27, 2013 - 10:42 PM
 That looks like a great project! You didn't waste any time getting her tore down. I'll dig around tomorrow, and find a flywheel. I'll be watching this project! :thumbs:
Matt
  • Amigatec said thank you
