Simplicity Landlord 101 (1966) Hi-lo Gear Kit Info ?
12 replies to this topic
#1 IamSherwood OFFLINE
  • 8,390 Thanks
Posted February 02, 2013 - 11:05 AM
I'm working on my daughters Landord, and it has a hub on the transaxle input shaft, and
I have a lever, and a bracket.
Does anyone have any pictures, or info on this.
There is nothing in the parts book, or manual.
Thanks
#2 massey driver ONLINE
massey driver
  • 1,283 Thanks
  • 1,526 posts
Posted February 02, 2013 - 11:26 AM
http://gardentractor...eed-conversion/  Not sure if this is what your looking for.
  • IamSherwood said thank you
#3 IamSherwood OFFLINE
  • 8,390 Thanks
Posted February 02, 2013 - 12:24 PM
Thanks MD, but what I have, and am looking for, is much different.
I'll get some pics of what I have.
#4 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,570 Thanks
  • 1,298 posts
Posted February 02, 2013 - 01:27 PM
I think you might find what you are looking for at simpletractors.com.Poke around there.
#5 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted February 02, 2013 - 01:30 PM
Sounds like you're talking about a #990348 Two-Speed Pulley.
Here's the manual for it:
http://gardentractor...o-speed-pulley/
#6 IamSherwood OFFLINE
  • 8,390 Thanks
Posted February 02, 2013 - 01:41 PM
Yes Greg, that's the ticket there.
Thank you very much.
#7 IamSherwood OFFLINE
  • 8,390 Thanks
Posted February 02, 2013 - 02:10 PM
Looks like I've got everything except the shoulder bolts that hold
the fork, and the pivot/pivot bearings. (part #s AE and AF)
No big deal on the shoulder bolts. I can find something for that.
Any idea on what material the pivot bearings (AF), would/should be?
#8 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted February 02, 2013 - 02:42 PM
You might want to look at this.
#9 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted February 02, 2013 - 02:54 PM
Will, you can use delrin or nylon for the pivot bearings. I think most use the delrin. You can also do away with the aluminum pivots and make the pivot bearings to the specs found in this thread:
http://www.michaelst...674&whichpage=1
#10 IamSherwood OFFLINE
  • 8,390 Thanks
Posted February 02, 2013 - 02:59 PM
Thanks for that link.
I think I've got some brass hex mat'l.
I'll get my brother to spin them up in the lathe, and
then I can drill, cut, and file the slots in.
For sure, not going to pay $60 in 2004 prices.
Thanks
#11 IamSherwood OFFLINE
  • 8,390 Thanks
Posted February 02, 2013 - 03:01 PM
Says I need to logged in.
I thought about nylon, but won't heat be an issue?
#12 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted February 02, 2013 - 03:11 PM
Here's the specs for the pivot bearings.
I've heard no complaints from anyone that used the nylon, so I don't really know about the heat being an issue.
#13 IamSherwood OFFLINE
  • 8,390 Thanks
Posted February 02, 2013 - 03:18 PM
Thanks for digging that up.
Nylon it'll be.
For what it takes, I'll get him to spin up 4 while he's at it.
That's what brothers are for, right. :D
Thanks for all the help guys.
