New (to Me) Jd Tractor!
john deere
41 replies to this topic
#16 grnspot110 ONLINE
grnspot110
  • 4,283 Thanks
  • 2,682 posts
Posted February 02, 2013 - 05:33 PM
I have a question for anyone familiar with the Ertl pedal tractors. This one has a mark below the steering wheel in the shape of a (script) "E", looks like a fine weld bead & wraps slightly around the right side. Has anyone seen this before?
The tractor doesn't appear to have been re-painted! ~~ Lowell
  • larryd said thank you
#17 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted February 02, 2013 - 06:50 PM
Lowell,
That isn't part of the casting, and was added. Not sure if there might have been a hole at one point, and then repaired. You should know better once you split the halves and see what it looks like from the inside.
  • grnspot110 and larryd have said thanks
#18 grnspot110 ONLINE
grnspot110
  • 4,283 Thanks
  • 2,682 posts
Posted February 03, 2013 - 04:57 PM
The mark turned out to be something in the glue line, scraped right off with a sharp chisel! ~~ Lowell
  • johndeereelfman and larryd have said thanks
#19 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted February 03, 2013 - 08:17 PM
Great Lowell. Glad to see that no damage was done, and the value of the tractor wasn't effected.
#20 grnspot110 ONLINE
grnspot110
  • 4,283 Thanks
  • 2,682 posts
Posted February 06, 2013 - 05:47 PM
Painted the body halves today:
Will sand & paint the wheels tomorrow.  Decals & hub caps are here, axle caps should be here tomorrow.  When I get the tractor done, I'll restore the cart, then get some plywood to mount them on the JD #10 dump cart for shows & parades!  ~~  Lowell
  • KennyP, johndeereelfman and larryd have said thanks
#21 KennyP ONLINE
  • 40,056 Thanks
  • 46,736 posts
Posted February 06, 2013 - 06:05 PM
That's a bit different from a GT, huh? That will look awesome on the cart!
#22 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted February 06, 2013 - 06:46 PM
Does the motor have compression, or are you going to rebuild it? LOL  It's looking good Lowell. You should go to the hardware store and buy a piece of chrome, straight 1 1/2" sink drain pipe, and mount it to the hood. That would dress the tractor up really nice without ruining the casting. Can't wait to see if finished. :thumbs:
#23 grnspot110 ONLINE
grnspot110
  • 4,283 Thanks
  • 2,682 posts
Posted February 14, 2013 - 05:25 PM
Finished up the tractor & cart a couple days ago!
Today I cut prepped & primed the 1/2" plywood top for the #10 cart:
Will paint it JD "Ag Yellow" tomorrow.  ~~  Lowell
  • KennyP and larryd have said thanks
#24 grnspot110 ONLINE
grnspot110
  • 4,283 Thanks
  • 2,682 posts
Posted February 16, 2013 - 06:10 PM
Finished up the #10 cart w/520 pedal tractor today:
Will need to extend a couple of drawbars before parade day to allow for tighter turns.
Lowell
  • KennyP, CRFarnsworth and larryd have said thanks
#25 KennyP ONLINE
  • 40,056 Thanks
  • 46,736 posts
Posted February 17, 2013 - 09:24 AM
Looks good, Lowell! Now you need to find some smaller one's for the pedal tractor trailers!
#26 pigsitter OFFLINE
pigsitter
    enjoyin the livin part of life!
  • 1,229 Thanks
  • 1,083 posts
Posted February 17, 2013 - 09:48 AM
I'm thinking a bored assembly line worker decided to put his own personal ertl emblem on the tractor, I have pulled several auto door panels to find hello and other greetings written on the inside of the panels
As always great work on the tractor!
#27 grnspot110 ONLINE
grnspot110
  • 4,283 Thanks
  • 2,682 posts
Posted March 18, 2013 - 06:51 PM
Started on the 520 "Industrial" today,
Color will be Rustoleum "Extreme Yellow", have the decals on hand:
It will ride the #15 cart in parades & shows.  May try making some attachments for it, eventually!  ~~  Lowell
#28 grnspot110 ONLINE
grnspot110
  • 4,283 Thanks
  • 2,682 posts
Posted March 19, 2013 - 04:43 PM
Painted the body parts & wheels today:
Re-assembly tomorrow!  ~~ Lowell
#29 grnspot110 ONLINE
grnspot110
  • 4,283 Thanks
  • 2,682 posts
Posted March 23, 2013 - 04:48 PM
Put the "Industrial" back together today!
Will attach it to the plywood & that to the #15 cart for parade & show duty.
Next, a PINK pedal car to be made into a JD style, similar to this:
I have the car, just need to sand it down, repaint it & attach it to my #50 cart:
I need to repaint the cart too!  ~~  Lowell
  • CRFarnsworth and larryd have said thanks
#30 grnspot110 ONLINE
grnspot110
  • 4,283 Thanks
  • 2,682 posts
Posted March 27, 2013 - 04:25 PM
Painted the body of the car today:
Had a problem with the tape on the fenders (fixable), so I'll have to wait a few days to finish it.  ~~  Lowell
Also tagged with one or more of these keywords: john deere
