Cub Cadet 1100 Refurbishment
75 replies to this topic
#46 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted February 26, 2013 - 04:17 PM
thats turning out real well cant wait to see more updates
  • LTD said thank you
#47 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted February 26, 2013 - 06:43 PM
Today I did some assembling. I got the rear wheels installed. I also got the dash pedestal,grill,nose piece and grill screens installed.
I tried to put the gas tank on but the mounts are hitting on the air cleaner. So I think I am goingto haveto cut out a small piece of one of them. Shoudn't be a big deal though. It's a lot better than a cut in the frame.
Edited by LTD, February 26, 2013 - 06:44 PM.
  • bgkid2966 and twostep have said thanks
#48 IHCubGuy ONLINE
IHCubGuy
  • 1,508 Thanks
  • 1,587 posts
Posted February 26, 2013 - 08:19 PM
Looking very good.
#49 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted February 26, 2013 - 08:54 PM
Looks great! I am liking the red!
#50 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted March 06, 2013 - 07:36 PM
Been a while since an update. I put the first coat on the last of the white parts.  I also started taking the deck apart. It has a lot of surface rust but there are no spots rusted through. The blades came off terrible. Had to apply quite a bit of heat, but two of them did finally loosen up. The center one won't budge though.
  • KennyP and twostep have said thanks
#51 KennyP ONLINE
  • 38,230 Thanks
  • 45,863 posts
Posted March 07, 2013 - 06:13 AM
Parts are looking good. Hope you can get that blade off.
#52 twostep OFFLINE
twostep
    Rockstar
  • 1,983 Thanks
  • 2,534 posts
Posted March 07, 2013 - 08:38 AM
Yup, good luck with that blade! And I hope those spindles are usable... they aren't cheap to replace!
#53 KennyP ONLINE
  • 38,230 Thanks
  • 45,863 posts
Posted March 07, 2013 - 08:46 AM
Try heating the nut and melting some candle wax into the threads. Just don't get it so hot you are messing up the bearing seals!
#54 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted March 07, 2013 - 08:19 PM
Today I put the second coat of white on the hood,dash and tunnel cover. I got the center blade off with a little more heat and lots of PB blaster. The spindles aren't in good shape. One of the outer spindle's has a hole in it. The keyway is stripped and the pulley is shot in the center spindle. I think I have some out back though.
#55 welderman85 OFFLINE
welderman85
  • 38 Thanks
  • 53 posts
Posted March 07, 2013 - 08:43 PM
great work i really like the colors
#56 twostep OFFLINE
twostep
    Rockstar
  • 1,983 Thanks
  • 2,534 posts
Posted March 07, 2013 - 11:06 PM
Man those spindles are rough... The deck itself doesn't look like it's too bad off. It's nice and straight anyway. Still no rust through spots?
#57 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted March 08, 2013 - 09:00 AM
None that I could find. I think the PO must have got another deck shell and swapped out the spindles.
#58 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted March 10, 2013 - 04:23 PM
Made some progress over the past couple of days. The PTO switch arrived in the mail a couple of days ago and I have been working on the wiring since then. The PO made a real mess of it. I ended up cutting all the covering off to fix the splices and take out unneccesary wires. I wired out the safety switches; hate those things. They go bad at the worst times. I have all the wiring issues taken care of now;hopefully. The starter is away for a rebuild so I will know for sure when I get it back.I finished painting the hood yesterday and installed it. The dash still needs the aluminum panel,but I put it in place to get the hood lined up. I also got the tunnel cover and drive belt put on.
  • KennyP, Trav1s, CRFarnsworth and 1 other said thanks
#59 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted March 10, 2013 - 04:27 PM
Looks great! Almost there!
#60 IHCubGuy ONLINE
IHCubGuy
  • 1,508 Thanks
  • 1,587 posts
Posted March 10, 2013 - 06:45 PM
Its coming together now.  This is where I always start to get anxious and want to rush the rest of the build.  Always gotta make myself slow down and take my time.  Looks good Levi.
