Cub Cadet 1100 Refurbishment
75 replies to this topic
#16 KennyP ONLINE
  • 40,069 Thanks
  • 46,742 posts
Posted February 02, 2013 - 04:35 AM
Nice progress you have going here! I wonder if that shroud cover had a zee bend at the bottom to hold it in opposite the bolts?
  • LTD said thank you
#17 mjodrey OFFLINE
Posted February 02, 2013 - 05:08 AM
Things seem to be going along good.
#18 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted February 03, 2013 - 11:00 PM
Instead of sitting around watching the Superbowl tonight,I went out and got some more done on the 1100. So much more fun!!! I got the engine torn down as far as I need to so I can paint it.
I cleaned up the all the cooling fins and blew all the crud out of them. There is some paint down in between the fins, but I got all I could. Do you guys think they are clean enough?
After that, I took all the engine tin; cleaned it up and primed it.
The flywheel shroud soaking.
All primed and drying.
The last thing I did today was take apart the fender pan.
Battery box is a little rusty. LOL. Definitely goingto need to rework it.
The new ISO mounts came today also. Should be a big improvement over the old ones.
Paint should be here sometime next week;I'm hoping.
  • twostep said thank you
#19 twostep OFFLINE
twostep
    Rockstar
  • 1,987 Thanks
  • 2,538 posts
Posted February 03, 2013 - 11:49 PM
Nice progress. Thank you so much for doing something about that paint job!
What are you soaking the tins in? looks like hot water?
#20 KennyP ONLINE
  • 40,069 Thanks
  • 46,742 posts
Posted February 04, 2013 - 05:10 AM
Looks like some good progress. I'm a little curious as to your solution, also!
#21 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted February 04, 2013 - 10:22 AM
It's a secret solution passed down for years....  Just kidding, it is just water as hot as I can get it.Looks impressive though with the steam rising out it.
#22 KennyP ONLINE
  • 40,069 Thanks
  • 46,742 posts
Posted February 04, 2013 - 06:30 PM
I thought you had a secret potion working there! :bigrofl:
#23 IHCubGuy OFFLINE
IHCubGuy
  • 1,590 Thanks
  • 1,629 posts
Posted February 04, 2013 - 07:43 PM
Looking good.  I would say the fins are clean enough.  I usually clean them as good as I can get with a wire brush and then paint them.
#24 Ryan313 OFFLINE
  • 3,403 Thanks
  • 5,240 posts
Posted February 04, 2013 - 07:56 PM
Looking good!
I think that as long as you wire brush the fins the best you can, you will be fine; just make sure you use a brush that has wires long enough to reach the bottom. :thumbs:
#25 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted February 12, 2013 - 06:34 PM
Been a few days since I have worked on the 1100. The paint arrived a couple of days ago,but today was the first time I had a chance to do some spraying. It came out pretty well. I am goingto apply 1-2 coats of paint, then assemble, then give it one coat with it back together.
#26 Ryan313 OFFLINE
  • 3,403 Thanks
  • 5,240 posts
Posted February 12, 2013 - 06:43 PM
Paint looks great! I think it is going to look good in those colors!
#27 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted February 13, 2013 - 08:21 PM
 Made a bit of progress today. I got the frame done and attached the front axle and tires to it. I then got the transmission hung up along with the steering column and some other misc. parts. After painting all those parts in red I gave the rear wheels another coat. They aren't coming out as well as I would have liked because I didn't have a sandblaster to remove the paint on them. The red is going on extremely nice though.
#28 Ryan313 OFFLINE
  • 3,403 Thanks
  • 5,240 posts
Posted February 13, 2013 - 08:33 PM
Looking good with the paint! I am surprised that the rear hubs only use 3 lug bolts!
#29 IHCubGuy OFFLINE
IHCubGuy
  • 1,590 Thanks
  • 1,629 posts
Posted February 13, 2013 - 08:48 PM
Looks to be coming along well.  Liking the red and white scheme.
#30 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted February 13, 2013 - 08:53 PM
Thanks!!! This tractor was IH's answer to a lower priced garden tractor. That is why it has the Peerless rear end and a Briggs and Stratton engine. I considered putting a 3 speed Cub Cadet rearend in it but all I plan on doing with it is mowing. Therefore,I can't see the need for a heavy duty rearend and there is one more speed in the Peerless anyway.
  • Ryan313 said thank you
