Cub Cadet 1100 Refurbishment
75 replies to this topic
#1 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted January 29, 2013 - 12:06 PM
  I started to tear down the 1100 to fix the muffler last night and I got a little carried away. :rolling:
This is what it looked like before teardown.
I can't stand that blue and black. So I decided I am goingto paint it red and white. I think it will look pretty cool. It doesn't have the right engine in anyway so it wouldn't be original at any rate.
Anyway here are some pics. of the teardown.
Coming apart.
Engine's out. It ran great so all it is goingto need is a paint job.
Getting ready to drop the transmission.
Transmission is out.
Paint is peeling pretty bad. What was the guy thinking that painted that. :mad2:
The ISO mounts have seen better days.
I will keep you guys updated on the progress!!
  • daytime dave, IamSherwood, KennyP and 2 others have said thanks
#2 IamSherwood OFFLINE
  • 8,395 Thanks
Posted January 29, 2013 - 12:25 PM
You got carried away? Uhmmm yea.
Did you find the muffler? :rolling:  :rolling:
Looking forward to seeing it go back together.
  • LTD said thank you
#3 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted January 29, 2013 - 05:40 PM
Eventually. LOL.
#4 daytime dave OFFLINE
  • 4,936 Thanks
  • 6,582 posts
Posted January 29, 2013 - 06:14 PM
Are you sure, really really really sure you want to repaint it?  I mean it kind of makes a statement.  Not one I would utter too loudly, but a statement none the less.
Good luck Levi, it will be interesting to watch.
Edited by daytime dave, January 29, 2013 - 06:15 PM.
#5 IHCubGuy ONLINE
IHCubGuy
  • 1,592 Thanks
  • 1,632 posts
Posted January 29, 2013 - 07:58 PM
I'd say you got quite the start on it.  Good luck with it and I will be looking forward to seeing the pics of it as it comes back together.
What is the torching on the frame from?  Needed to fit the carb of that engine?
Edited by IHCubGuy, January 29, 2013 - 08:02 PM.
#6 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted January 29, 2013 - 09:19 PM
Yes,but he cut out WAY more than he needed to. It needs a tiny piece taken out to clear the carburetor.
#7 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted January 29, 2013 - 09:33 PM
Today I took the front axle,transmission and frame over to the car wash and cleaned all the grease off. Then I took the frame over to my grandfathers and we welded it back up. I had a spare frame that somebody had cut the front off of and I cut a piece out of it to weld into the other frame.
After cleanup of the area.
The new piece of frame.
All welded up. I think it turned out pretty well. I will grind the weld down later.
#8 IHCubGuy ONLINE
IHCubGuy
  • 1,592 Thanks
  • 1,632 posts
Posted January 29, 2013 - 10:45 PM
That oughts do the trick Levi.  Looks like its progressing well.
#9 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted February 01, 2013 - 07:07 PM
Made some more progress today. Mostly cleaning up parts and priming.
The first round of parts.
Starting taking the deck apart. I am goingto to repaint it also.
Here is the starter all painted.
The carburetor came out nice.
  • KennyP and twostep have said thanks
#10 Ryan313 ONLINE
  • 3,404 Thanks
  • 5,241 posts
Posted February 01, 2013 - 07:15 PM
Looks like a great start! I will be watching!
#11 IHCubGuy ONLINE
IHCubGuy
  • 1,592 Thanks
  • 1,632 posts
Posted February 01, 2013 - 07:19 PM
Looking good Levi.  Keep it up.
#12 olcowhand ONLINE
  • 42,455 Thanks
  • 31,824 posts
Posted February 01, 2013 - 07:23 PM
I've never seen a Briggs flywheel shroud with a removable section at the top like this one.  Looks too clean not to be factory, and I assume you do have it?
#13 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted February 01, 2013 - 07:56 PM
I believe it is factory,but no I don't have it. I goingto see if I can locate one though.
#14 olcowhand ONLINE
  • 42,455 Thanks
  • 31,824 posts
Posted February 01, 2013 - 08:53 PM
You definitely MUST cover that hole as you will overheat for sure!  You could use sheet metal & rivet it in place at sides & bottom & use bolts up on top.
#15 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted February 01, 2013 - 09:27 PM
Thanks for the tip. I will do something with it. It looks like it was designed to provide easy access to the Magnatron.
