Model and Serial Number Help Needed.
4 replies to this topic
#1 DougM OFFLINE
DougM
  • 2 Thanks
  • 12 posts
Posted September 15, 2010 - 05:04 AM
I found the model number and serial number on my Sears Suburban 12 hp 6 speed tractor. The model number was hard to read. It appeared to be 9?93420. The number where the question mark is was very hard to read. Does anyone know what the model number is?
The serial number is 11197. Does anyone know what year this tractor was manufactured?
Thank you in advance for your help.
#2 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted September 15, 2010 - 03:25 PM
I've no idea on the Sears numbers, but hang tight, hopefully someone "in-the-know" with Sears ID's will come along shortly.
#3 caseguy OFFLINE
  • 1,629 Thanks
Posted September 15, 2010 - 05:01 PM
I'm not a Sears expert either, but I'm not having any luck with that number. If you could take a high resolution pic and post it, maybe we could figure it out together.
#4 bhts OFFLINE
bhts
  • 1,476 Thanks
  • 2,169 posts
Posted September 15, 2010 - 05:35 PM
That is not a sears model number that i have ever seen.It should be someting like 917.25350 which is a 68 sears surburban 12.Do you have a pic of the tractor or could you check the number again?
#5 tractormike OFFLINE
tractormike
  • 172 Thanks
  • 1,488 posts
Posted September 16, 2010 - 09:24 PM
I checked the sears numbers and the closest I could come to the number you gave was this, 917.99420 which is a 1966 sears suburban 12. It would have been blue and white. If you can post a picture of it and maybe we can help you out.
