Getting My E- Tank Ready Top Go!
16 replies to this topic
#1 Texas Deere and Horse OFFLINE
  • 14,862 Thanks
  • 15,511 posts
Posted January 28, 2013 - 05:32 PM
I have been getting our E-tank ready to start using maybe tomorrow. Got the top cut and bent some re-bar to go inside. I may need to ad another piece or 2, but I can do that with the water in it. Now to tie the bar together and fill it with water.
  • olcowhand, Alc, bgkid2966 and 3 others have said thanks
#2 KennyP ONLINE
  • 40,007 Thanks
  • 46,719 posts
Posted January 28, 2013 - 05:38 PM
That's basically what i did with my little tank. Just welded the rebar together. I'm afraid to put water in mine as yet. It'd go down to 10* for sure!
  • 14,862 Thanks
  • 15,511 posts
Posted January 28, 2013 - 05:41 PM
You can always stick a cattle tank heater in it if it gets that cold!
  • larryd said thank you
#4 KennyP ONLINE
  • 40,007 Thanks
  • 46,719 posts
Posted January 28, 2013 - 05:58 PM
I'll just wait, don't have a heater anyway! It's only 30 gallons!
  • 14,862 Thanks
  • 15,511 posts
Posted January 28, 2013 - 06:00 PM
I guess I need to figure out how many gallons this tank holds.. :reading_the_manual:
#6 DH1 ONLINE
DH1
    Electric Tractors
  • 5,353 Thanks
  • 5,603 posts
Posted January 28, 2013 - 06:02 PM
I think you will want to have the anodes, or the re-bar mounted in such a way that they can be easily removed for cleaning the crud off of them.
I found that with my 55gal tank I had to pull them out and clean them ever 2nd time I used it.
With clean anodes it works much faster.
Edited by DH1, January 28, 2013 - 06:05 PM.
  • Texas Deere and Horse, IamSherwood, CRFarnsworth and 1 other said thanks
#7 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted January 28, 2013 - 06:03 PM
Just my 2 cents. Flat steel is way better to use than rebar. I ran out and took this picture in the dark but I can pull the 3 pieces out and have them cleaned in half the time it took to do the rebar! And yes I finally found a use for those decoy weights I had laying around.
  • Alc, Texas Deere and Horse and larryd have said thanks
#8 Texas Deere and Horse OFFLINE
  • 14,862 Thanks
  • 15,511 posts
Posted January 28, 2013 - 06:07 PM
I have a heavy 1/4" screen out of one of our portable screen plants, I was thinking about using it. It is 3' X 5', it would take a couple of them.
#9 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted January 28, 2013 - 06:11 PM
More clean surface area means faster cleaning! Temps will be good here tomorrow might try to put those rims I been working on back in the tank!
#10 DH1 ONLINE
DH1
    Electric Tractors
  • 5,353 Thanks
  • 5,603 posts
Posted January 28, 2013 - 06:16 PM
Wide Flat bar is the way to go, individual pieces, more surface area I think would work better, faster, stay cleaner longer, and be quick and easy to clean.
In my picture above I have t bar tree stakes, (all I had at the time) hooked them up with small jumper leads and alligator clips.
As "sacsr" says
Edited by DH1, January 28, 2013 - 06:17 PM.
#11 KennyP ONLINE
  • 40,007 Thanks
  • 46,719 posts
Posted January 28, 2013 - 06:26 PM
I usually hang a 'donor' piece in and switch the leads. Does pretty good!
  • Texas Deere and Horse and sacsr have said thanks
#12 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted January 28, 2013 - 06:36 PM
To the top, that tank will hold about 275 gallons.
#13 IamSherwood OFFLINE
  • 8,395 Thanks
Posted January 28, 2013 - 07:41 PM
I agree, flat surfaces work best. I started with rebar. Pain to clean. Now I use old
bandsaw blades, from my sawmill.
I just had a thought.
Head to a construction site, and grab the discarded metal banding, from the
lifts of wood.
#14 IHCubGuy OFFLINE
IHCubGuy
  • 1,590 Thanks
  • 1,629 posts
Posted January 28, 2013 - 08:05 PM
I have been thinking about doing this for my MF620 snowblower housing. Only problem I have is that I dont think I have anything that it will fit in.  I have researched this in the past and I have forgotten all the ins and outs of it.  Guess I need to get it figured out again and find a suitable tank to put the blower in and get it started.
#15 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted January 28, 2013 - 08:20 PM
I did my dump cart in a big horse/cattle plastic water container......
