Onan Issue-solved
6 replies to this topic
#1 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted January 27, 2013 - 09:55 PM
Hey every one i have a Miller welder with a onan p180  that we had at the house and the aux power did not work and there was other issues and it was away for almost 4 years it was in the repair shop then into storage ! where it sat  and sat well we got it home abit ago .. and i mounted it on a trailer when we had it before is also had a Knock/tick i personally thought that it was a rod bearing but the engine has low hours Maybe 200 if that well after all that time it sat then i started a few days ago then it was flooding its self out so i took apart the carb expecting to replace the Floats with brass ones i cleaned the carb with no luck ... so i took the needle valve and used polishing compound with a Q tip and cleaned up the seat that fixed that then it starts leaning it self out so today i took the intake manifold off and removed the valve covers and found the problem ! i also cleaned the carb now it runs Mint ! as you can see in the picture the cap thing laying in the bottom of the valve box there is a cap that goes on the valve stem and some how it fell off ! i put i back in and it runs Awesome ! and quiet ! no knock ! also the onan engines you can adjust the valve clearance !
thats all for today !
cheers
Ty
Welder with stuff on it !
valve body pictures with cap removed from base
valve body with cap installed From Google
Cap From google
Edited by 8tyman8, January 27, 2013 - 10:11 PM.
  • KennyP, iron Mike and boyscout862 have said thanks
  • 14,862 Thanks
  • 15,511 posts
Posted January 27, 2013 - 10:00 PM
Ty, I don't see what you are talking about, but glad you got it fixed and now it's running good. :thumbs:
#3 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted January 27, 2013 - 10:09 PM
I just edited it as for some reason i did not get a picture of the part that fell out ! so i looked on google and found them
  • Texas Deere and Horse and KennyP have said thanks
  • 14,862 Thanks
  • 15,511 posts
Posted January 27, 2013 - 10:13 PM
Thanks, I see what the issue was, maybe that is what is the matter with my Onan. I have to run it at 3/4 choke to keep it running.
#5 KennyP ONLINE
  • 40,054 Thanks
  • 46,736 posts
Posted January 28, 2013 - 05:30 AM
Took me a minute to spot it. Thanks for the info!
#6 JDBrian OFFLINE
  • 9,635 Thanks
  • 14,156 posts
Posted January 28, 2013 - 06:07 AM
I wonder how that got off of there. From a previous disassembly or maybe from over revving the engine?
#7 Alc OFFLINE
  • 7,116 Thanks
  • 7,529 posts
Posted January 28, 2013 - 06:45 AM
Glad to hear it's fixed ! Does everything else work on the welder too ,Al
