Clutch Off The Db, Now What? (with Pics)
10 replies to this topic
#1 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted January 26, 2013 - 04:33 PM
Ok, today I finally got the clutch off and I need you guys to tell me what's wrong with it. I only got 8 balls out of the bearing, and nothing looks really broken, so all help and advice appreciated!image.jpg image.jpg image.jpg
  • 14,814 Thanks
  • 15,501 posts
Posted January 26, 2013 - 04:46 PM
What model DB are you working on?
#3 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted January 26, 2013 - 05:01 PM
It is a 917.575.138
#4 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted January 26, 2013 - 05:04 PM
It probably just needs a good cleaning.
#5 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted January 26, 2013 - 05:16 PM
What should I clean it with, and how should I clean it?
#6 Texas Deere and Horse OFFLINE
  • 14,814 Thanks
  • 15,501 posts
Posted January 26, 2013 - 05:20 PM
It looks to have grease in the clutch material. I would use brake cleaner and spray it several times to get all the grease I could. Make sure if there are any bearings or bushings that you grease then back up after you put it together. don't over grease the clutch or you will have grease all over the clutch linings again.
#7 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted January 26, 2013 - 05:25 PM
Look closely the pulley should have a small ball it, this is to grease the bushing. Make sure you clean that out so you can grease it later. I believe the lining is rivited to the plates. Just clean the dirt and grease off, and it should be ok.
#8 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted January 26, 2013 - 05:52 PM
It is a 917.575.138
you sure that ending is correct? My list goes from 917.575131- 917.575144, it skips anything in between.
#9 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted January 26, 2013 - 05:55 PM
Yep they made one. One of the last 4 models built.
#10 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted January 26, 2013 - 06:44 PM
oh, thats a neat fact i didnt know! So it is one of the last of the series?
#11 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted January 26, 2013 - 07:00 PM
It's one of the last 5 made.
The last 5 were the 138, 139, 142, 143, and the 144. I have part of a 144 out back.
Yours was made about 1962.
Edited by Amigatec, January 26, 2013 - 07:01 PM.
  • tractorman604 said thank you
