* * * * * 2 votes
Bolens - Montgomery Wards Squire 6 Restore..
squire 6 bloens 600 montgomery wards
125 replies to this topic
#76 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted February 07, 2013 - 10:31 AM
Brian, what's the OD of that steering wheel hub?
Will, It measures 1.758" with paint on it.
What are you thinking??
  • IamSherwood said thank you
#77 IamSherwood OFFLINE
  • 8,390 Thanks
Posted February 07, 2013 - 11:48 AM
If you can't find a bolens chrome cap, the cap on a simplicity landlord
is the same size. So, allis...will fit too.
 has the 3 notches for the spokes, but no hole
for bolt.
#78 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted February 07, 2013 - 12:16 PM
Steering Wheel shaft and wheel are now separated. It was all my 30T press wanted and it sounded like a rifle when she let go. :D Lots of rust and rust pits on the shaft.
2013-02-07_10-44-58_868.jpg 2013-02-07_10-45-16_395.jpg 2013-02-07_10-55-33_835.jpg 2013-02-07_10-55-59_4.jpg
#79 IamSherwood OFFLINE
  • 8,390 Thanks
Posted February 07, 2013 - 12:35 PM
There's no shoulder on that shaft.
Good thing the wheel was rusted on, or it might have slid
all the way down the shaft.
#80 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted February 07, 2013 - 01:56 PM
The way it's captured in the tower with the gear on one end and the steering wheel on the other, it can't go anywhere. But if the wheel came off, the shaft could fall to the ground.
#81 Bolens 1000 ONLINE
  • 14,902 Thanks
  • 18,101 posts
Posted February 08, 2013 - 01:42 PM
Found a Pulley and shaft but the price is way too high for a rusted used assembly IMO
http://www.ebay.com/...=item4154d87acb
#82 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted February 09, 2013 - 11:40 AM
I think I have a lead on the PTO engagement rod, rear fender/tool box, good steering wheel and a good drive shaft double pulley. I will know the first of the week on those parts. I did get to do more tear down yesterday in between the interruptions of work :D , I hate when work gets in the way. :wallbanging:
Here are a few photos of the brake setup on the trans. NOTE, the brake drum has already been removed from the input shaft.
2013-02-08_13-10-35_151.jpg 2013-02-08_13-10-06_11.jpg 2013-02-08_13-10-14_32.jpg 2013-02-08_13-10-25_251.jpg
I did bring home a lot of stuf to run in my small E-tank this weekend and will update as I can.
#83 KennyP ONLINE
  • 37,442 Thanks
  • 45,469 posts
Posted February 09, 2013 - 12:01 PM
Glad you may have some parts, Brian! What does the second pad do?
#84 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted February 09, 2013 - 12:33 PM
Kenny, From what I can figure out. The tractor has a brake on the drive shaft and also on the output shaft to the rear-end so you have a brake when it's in neutral.
#85 KennyP ONLINE
  • 37,442 Thanks
  • 45,469 posts
Posted February 09, 2013 - 12:46 PM
Thought that's what it was.
#86 wilberj OFFLINE
wilberj
  • 4,988 Thanks
  • 5,588 posts
Posted February 09, 2013 - 12:51 PM
attachicon.gif2013-02-07_10-44-58_868.jpgattachicon.gif2013-02-07_10-45-16_395.jpgattachicon.gif2013-02-07_10-55-33_835.jpgattachicon.gif2013-02-07_10-55-59_4.jpg
Is that steering wheel 15" diameter with a 3/4 shaft?
#87 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted February 09, 2013 - 02:21 PM
Jerome, I think so, but will have to check. It's the same as the 600/900 I've been told.
#88 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,868 Thanks
  • 1,850 posts
Posted February 09, 2013 - 02:55 PM
My son has one of these Wards / Bolens tractors but someone had cut the hood up to put in a different engine.
He has found the correct engine for it but hasn't been able to find another hood yet.
If anyone has a hood for sale for this style tractor would you please contact me by email ?
I sure would appreciate it.
Edited by jdcrawler, February 09, 2013 - 02:57 PM.
#89 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted February 10, 2013 - 09:49 PM
I am going to have to replace the plastic bushings that go in the left foot rest for the Brake/Clutch pedal, I will need 2 of them. I thought I had a parts list for the 600, but I can't find it in my downloads. Does anyone know if we have one here?
2013-02-10_14-31-00_445.jpg 2013-02-10_14-30-29_93.jpg 2013-02-10_14-30-35_915.jpg 2013-02-10_14-30-52_494.jpg
#90 IamSherwood OFFLINE
  • 8,390 Thanks
Posted February 10, 2013 - 10:13 PM
MF5 and 6 RERs use those bushings for front spindles. They should be easy enough to find.
Also tagged with one or more of these keywords: squire 6, bloens, 600, montgomery wards
