* * * * * 2 votes
Bolens - Montgomery Wards Squire 6 Restore..
squire 6 bloens 600 montgomery wards
125 replies to this topic
#61 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted February 05, 2013 - 12:27 AM
Montgomery Ward and Company records, 1872-2000
Descriptive Inventory for the Collection at Chicago History Museum, Research Center
By Jane McCarthy, 2003-2006
Please address questions to:
1601 North Clark Street Chicago, IL 60614-6038
Web-site: http://www.chicagohistory.org/research
Title: Montgomery Ward and Company records, 1872-2000.
Main entry: Montgomery Ward  Inclusive dates: 1872-2000
Size:75 linear ft. (171 boxes)
12 sound recordings. Original.
Telephone: 312.642.4600
Fax: 312.266.2077
Answers to many visitor information questions can be found in the
plan a visit section. If you need further assistance please call 312.642.4600 or use our contact form.
Series 7. Advertising, promotion, consumer education 1912-1997 (boxes 71-76)
Series 8. Catalogs, distribution centers/catalog houses, stores 1872-2000 (boxes 80-98)
...In the 1980's, Ward's deposited some of its archives dating between 1860 and 1989 at the American Heritage Center at the University of Wyoming in Laramie (Wyo.). A descriptive inventory of this collection can be found in Box 58, Folder 6 of the collection at Chicago History Museum.
http://chsmedia.org/...M/Wards-inv.htm
Hope this helps
Thanks, I will be contacting them to see if they have any info on the Bolens connection. And maybe any Catalogs from back then.
#62 Bolens 1000 ONLINE
  • 14,900 Thanks
  • 18,100 posts
Posted February 05, 2013 - 05:46 AM
Looking Good Brian!
#63 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted February 05, 2013 - 11:41 PM
Here are a few more photos of the tear down for the thread.
If anybody see something I need to address, please post it.
Idler Arm and Tie Rod , Spindles, Front axle.
2013-02-05_16-52-06_423.jpg 2013-02-05_16-52-15_546.jpg 2013-02-05_16-55-39_193.jpg
Front Pedestal and slims,
Clutch, Brake linkage,
2013-02-05_17-01-36_805.jpg 2013-02-05_17-03-27_337.jpg 2013-02-05_17-03-35_167.jpg 2013-02-05_17-03-43_623.jpg
Drive Shaft double pulley with broken spots,
Clutch Idler pulley, not right at all,
#64 KennyP OFFLINE
  • 37,417 Thanks
  • 45,461 posts
Posted February 06, 2013 - 04:16 AM
Looks like a solid front axle under there. I can't say what's wrong, as I haven't a clue of what's right on this!
#65 Bolens 1000 ONLINE
  • 14,900 Thanks
  • 18,100 posts
Posted February 06, 2013 - 08:47 AM
Besides the idler and pulley everything else looks great.
If your going to replace the broken pulley you can find one from the following models, 600,650,750 Part number- 1714893
The newer G Series tractors (G10 G12 etc.) may work as well but used a different part number 1731340 , Not sure what the difference is between  a 1714893 and the 1731340
#66 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted February 06, 2013 - 11:28 AM
Kenny, None of us do, if it's different from the Bolens 600.
:bigrofl: :bigrofl: :bigrofl:
Bolens 1000 Said;
Thanks for the info Brian. :thumbs:
Does the front axle look the same as the one on the 600?
#67 Bolens 1000 ONLINE
  • 14,900 Thanks
  • 18,100 posts
Posted February 06, 2013 - 12:03 PM
Interesting, Looks like the cast iron center axle support is different as well and has a lip added on the end to attach the hood..
#68 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted February 06, 2013 - 12:36 PM
Here is a couple better photos of that mount.
  • Bolens 1000 said thank you
#69 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted February 06, 2013 - 05:33 PM
I got more tore down today between fixing stuff for our plant.
The Clutch/Brake rod and PTO Shaft came out of the Steering Tower with little effort.
2013-02-06_14-22-16_689.jpg 2013-02-06_14-22-25_516.jpg 2013-02-06_14-22-49_24.jpg
The PTO Handle/Detent Spring came off by driving out the Spring Roll pin. The main PTO shaft was frozen solid in the PTO handle base and needed help from a Rose Bud on the Torch to come apart. I guess this is why someone cut the PTO Idler off the end of the shaft.
2013-02-06_14-37-51_625.jpg 2013-02-06_14-38-05_332.jpg 2013-02-06_14-42-35_958.jpg 2013-02-06_14-47-11_725.jpg 2013-02-06_14-47-38_347.jpg
Maybe this is a Factory setup, but I doubt it.
The Steering wheel is seized to the Steering Shaft, so I took off the Pinion Gear off the other end to remove the shaft, it also took a little heat to get the Spring Roll Pin to move..
How is the Steering Wheel kept on the shaft, there is no set screw to hold it on. I can't tell, but I wonder if there is supposed to be a cap bolt in the end of the shaft?
Removed the Bushing and holder to inspect the bushing.
The Steering Pinion Gear looks pretty good, with some wear.
  • IamSherwood, KennyP and Newpaws493 have said thanks
#70 KennyP OFFLINE
  • 37,417 Thanks
  • 45,461 posts
Posted February 06, 2013 - 06:15 PM
Brian, I don't know anything about the Bolens either. All I can say is it looks great to me. I do believe that steering wheel has grown onto the shaft! Good luck with that!
#71 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted February 06, 2013 - 09:47 PM
Good thing is Kenny, I can give it some heat before worrying about melting the covering, steel spokes!!
#72 IamSherwood OFFLINE
  • 8,390 Thanks
Posted February 06, 2013 - 10:21 PM
Sure looks like there would have been a bolt holding the wheel on.
Is that just dirt, packed into the hole?
#73 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted February 06, 2013 - 10:42 PM
Will, It was full of rust and dirt and had been partially painted over. :wallbanging:
#74 Bolens 1000 ONLINE
  • 14,900 Thanks
  • 18,100 posts
Posted February 07, 2013 - 06:13 AM
Looks like your making good progress Brian!
The Bolt holding the spring is not original :D
Bolens Used a chrome Cap that had a bolt in the center to hold the wheel on.
#75 IamSherwood OFFLINE
  • 8,390 Thanks
Posted February 07, 2013 - 07:48 AM
Brian, what's the OD of that steering wheel hub?
Also tagged with one or more of these keywords: squire 6, bloens, 600, montgomery wards
